Question about Whirlpool 24 in. DU920PW Built-In Dishwasher
Water willnot drain out of machine
At end of cycle dishwasher fails to drain the water out , have cleaned screens
thank you
Beth
  • Anonymous Mar 09, 2009
    A POOL OF WATER IS LEFT IN THE SCREEN AREA AFTER THE CYCLE IS DONE.
    Problem Solver:
  • 7 Answers
What brand?
Posted on Jan 27, 2009
Machine won't pump out last water after cycle.
Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/.../Does+not+drain+the+water+at+the+end+o...
iFixitThe dishes seem clean, but the water from the last cycle remains in after it has stopped. ..... noticable cracking noise when the machine was triying to drain the water.... to purchase a timer unnecessarily and they usually won't take them back.
Checking a Drain and Circulating Pump in a Dishwasher ...? 4:17www.youtube.com/watch?v=oLPBlkIsB5sMar 26, 2010 - Uploaded by ApplianceHelpOnlineIf your dishwasher doesn't pump out or will not wash watch this video. ... GE Nautilus Dishwasher wont run - fills water and doesnt drain - motor ...How to repair a dishwasher, not draining - troubleshoot ...? 6:18www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYHow to repair a dishwasher, not draining - troubleshoot Whirlpool ... awhile but now blade on grinder won't spin. what should be my next step? thnx ... from the bottom to access the water pump. but this was much simpler and it worked. thanks. ... If I manage todrain it now, I'll do what this video instructed :).
Oct 19, 2015 | Dishwashers
Water is not draining
First, Is any water draining? If yes, look for restrictions or siphoning back into the machine. Hair and paper are common restrictions on the anti-siphon/overflow device. It's' on the sink top. Remove the cap, take a long nose pliers to remove the inner top plastic piece. Remove the junk - hair, paper, etc. Put a inverted cup and run the drain cycle. Move junk and water will come out. Re- assemble. Also check for kinks in the drain hose(s). Also clean out the filter and screen in the dishwasher. Watch out for broken glass. If new garbage disposer, make sure the knock out plug was remove -- should see water enter from the dishwasher. If you don't have an anti-siphon device, get one. Otherwise drain water will back into the dishwasher.
Nov 23, 2013 | Tricity Bendix Dishwashers
My Kenmore dishwasher does not drain out, What could be the problem?
No drainage, or poor drainage issues are usually caused by either a failed drain pump, or the sump area under the sprayer is clogged with debris. The sump is the area at the bottom of the tub where water collects on the initial fill. A wash pump cycles the water throughout the wash cycle, followed by the same water being drained from the unit by means of a drain pump. This area is usually covered by a coarse screen and fine screen to prevent debris from accumulating. But, over time, some debris may still get past the screens and collect in the sump. This usually results in poor cleaning results due to restricted water flow through the spray arms, and poor draining.
I would recommend you remove the lower spray arm and screens and check the sump area for obstructions. If the unit still has standing water inside, use a wet/dry shop vac to drain. Remove the drain line from your sink and pull a vacuum on the end of the dishwasher drain hose. If the water drains freely from the unit, then you probably have a bad drain pump. If the water will not drain, you have a clog somewhere. Check your drain lines and pump for obstructions.
If you have any questions, please post back with a MODEL NUMBER. I hope this helps you.
Aug 15, 2011 | Kenmore Dishwashers
Model Free standing dishwasher SGS 5002 GB 14 yrs old. The dishwasher does not drain. The dirty water is left in the bottom at end of cycle. I have ensured outside drain is unblocked: I have cleaned all...
Please check if the drain valve is weak/faulty or does not get the votage to open during the cycle , his can be your fault . Also it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Jun 13, 2011 | Bosch Dishwashers
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Dishwasher not emptying at the end of its cycle. If water siphoned out will work temporarily then fails again, with water remaining standing inside machine. Check water indicator light is on, goes off when...
Not sure of your light indicator; check the manual. But fyi there should be a little water left in, so the rubber seal doesn't dry out. More than that, and could be clogged drain or bad solenoid, which tells it to open and drain. See: http://www.partselect.com/repair.aspx?appliance=dishwasher&part=water-wont-drain
Sep 17, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Older Kitchenaid Dishwasher doesn't fully drain and smells
Hi Jay. Remove the lower front panel and you will see the drain hose. On the machine end of the drain hose is a small drain pump. Disconnect the hose and the pump and you will most likely find a partial blockage in the form of a piece of glass or something preventing a total drain.
please mark this answer as a fixya!
Mar 09, 2009 | Dishwashers
Holding water
are the dishes getting clean at the end of the cycle, if not then there could be foreign debris in the pump housing that can cause this, needs to be dismantled and cleaned out, if dishes are clean then the pump impeller will need to be replaced
Apr 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool 24 in. DU920PW Built-In Dishwasher Logo
87 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
