Question about HP LaserJet 3600n Printer
57.04 error in hp3600 - HP LaserJet 3600n Printer
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
Hp 3600 cpr sensor out of range how do i repair this
CPR Sensor out of range for color hp3600 printer
Mar 29, 2013 | HP LaserJet 3600n Printer
The colours are nonexistence in some places and very pale hp3600
How does the inside of the printer look? If it is very dirty, then it is possible that the laser scanners are polluted. The other possiblity is that one bad cartridge can cause all colors to print poorly due to the fact that all the high voltage is driven off one board on these printers. If you recently installed a new cartridge, try swapping it out for the old one, if the print quality improves, you have a bad cartridge for sure and should have the store you bought it from replace it.
Jul 30, 2011 | HP LaserJet 3600n Printer
After changing the toner cartridge of an HP3600 the printer calibrated but then has started printing in a Sepia type colour and not giving a true colours
Any chance you just changed the magenta cartridge? Your problem sounds like a defective cartridge, which happens often if you are using a refilled or remanufactured unit. From the front control panel you can go to troubleshooting menu and then pq troubleshooting to print a set of pages that consists of"
1 page of each color cartridge
1 white page
1 configurationpage
1 page that tells you how to use the pq troubleshooting pages
If the sepia problem is accross all of these pages then if most likley is the magenta cartridge that is bad. If it is only one page that is bad the color that is bad will be the bad cartridge.
Mar 28, 2011 | Office Equipment & Supplies
How can i fix hp3600 59.Fo error
59.X PRINTER ERROR A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error 1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor’s cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
Apr 21, 2010 | HP LaserJet 3600n Printer
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
54.15 error code
Error Code 54.XX
Control Panel Message: Printer Error
Description:
15 Yellow CPR sensor
Recommended Action: Turn the printer off and then on, and then check the following itmes
Check the connections. Replace the color-registration detection assembly.
Description: Printing cannot continue. There is a sensor malfunction.
XX Description
15 - Yellow toner remaining sensor (J1014 toner level sensor)
Jun 24, 2009 | HP LaserJet 4700 Printer
The printer is not working and it seems the laptop now reads `hp3600 instead of 3650. when i try to print from word or the online toolbar, nothing happens. it usually says 2 documents on queue or some...
two solutions. One is log into HP.com and go to online chat.
Before doing to hp.com try to print and look to see if the print format is set to hp3600 or print to file. Sounds like it is set to print to file.
May 04, 2009 | Toshiba Satellite A205-S5804 Notebook
HP LaserJet 3600n Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
