Question about Intel Computers & Internet
Intel board red light - Intel Computers & Internet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intel Master
  • 2,226 Answers
On what board
Posted on May 25, 2014
Red light on motherboard
check mobo manual and/or manufacturer support website for the exact meaning of this blinking light !!! Then proceed with faulty (or mismatched) component (mobo, cpu, mem ??? )
Feb 13, 2014 | Intel DQ57TM Executive Series Motherboard
Please give me the audio driver of intel mother board d845glva
hi raju, just copy and paste the link i have given below to download your AUDIO DRIVER
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=7236&lang=eng
or click here
Operating Systems: Red Flag Linux Desktop 4.0*, Red Hat Linux 8.0*, Red Hat Linux 9.0*, SUSE Linux 8.2*
GOOD LUCK ! if your problem solved mean don't forget to rate
Dec 31, 2010 | Intel Desktop Board D845GLVA...
I have a red light color behind the green light color in my board.What did this mean? The board number is DQ965GF
hi..the indicator lights is meaning the board is found a shorted or not working parts.if u want find as fast remove all the IDE from the board and remove the memory and VGA if you have then clean the memory using paper eraser all the pin connectors then try to put it back the boot the board/power..good luck
Jun 15, 2009 | Intel Motherboard
Red light flashes and system not responding
Erratic power supply, at least hope its just that and not a burnt CPU thats keeping it from posting.
Sep 28, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
DX38BT
did you install the heatsink with thermal compound before installing windows?
Sep 27, 2008 | Intel DX38BT Desktop Board (BLKDX38BT)...
Vga display problem
There is one pin/wire on the VGA connector that translates to the color red on your screen. If you aren't seeing any red, I would suspect that there is damage to the integrated VGA connector on the motherboard, or a component failure in the circuit.
These are great desktop boards.
The Video bus on these boards are shared between the integrated (onboard) video card and port and the AGP slot. This means that you can only use one or the other. When you install an AGP card in the slot it overrides the integrated video including your problem.
If you are good with electronics I'd take a look at the board under the scope and look for damage.
I would rist check with intel on the warranty. You may be surprised. I've had several of these replaced via RMA through intel. They are a bit older but still by desktop board of choice.
May 21, 2008 | Intel D865GBF Motherboard
Compaq Evo D5 power light flashes red.
try to get to the jumper next to the cmos battery in the mainboard. by changing its position for some seconds while power is off and putting it back , cmos is cleard. start the board hit delete to enter setup and exit saving chages.
Nov 13, 2007 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
New installation of mother board
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
Oct 05, 2007 | Select Brands System on board CPU / VIDEO/...
Computers & Internet Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
