Question about Icom Tait T2010 T2015 T2020 T2030 T2040 Radio Programming Software Cd
Low Tx power output
Draws 6A current. Only 1W Tx pwr
  • Henare Jan 25, 2013
    It's UHF T2040. The signal level is correct on the collector tab of final PA transistor. That signal is fed thru the pcb but greatly attenuated. I hardwired the thru-tracklink on the pcb. Zero ohms on either side of pcb. Still signal loss. Is the feedback loop loading down the signal?
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Tricky question with a simple solution, May I suggest you join, as I did, yahoo group SPECIFIC to your radio Make/Model, like myself (I own A T2010, T2020 & T2030), you will receive expert info on your queries, plus you can download manuals, schematic diagrams and other goodies for your radio.
I hope this helps you.
Best regards,
Peter
Posted on Mar 05, 2013
Kenmore coldspot compressor draws 1.4 AMPS when running but when it does not start it draws 8 AMPS
When you turn the compressor off you have high pressure on the output side - If you do not wait for the unit to equalize pressures before restarting, often, a compressor will not start - when this happens it draws a lot of power as your measurements indicate.
The technical reason why unit draws so much power when it is stalled is that the motor acts as a generator in the reverse direction of current flow. The reverse current or back EMF serves as a brake to the incoming current. So if you have 8 amps rushing in and the motor generates a back emf of 6.6 while running the resultant draw is 1.4. Capiche?
If motor does not turn on after a cycle it is because the thermostat is not closing properly. I would change it. U might also want to check out the condition of the start relay or hard start cap. If that is not working properly the compressor will not start.
Feb 04, 2017 | Kenmore Refrigerators
Why does my car stereo overheat after 15-20 minutes?
There clearly is a fault. Probably with the output or driver stage bias. Something is getting hot and as it heats its value is changing. It will probably need an engineer with a service sheet to locate the fault. It is rarely the obvious culprit...
Apr 10, 2016 | Car Audio & Video
Cx-3300 low output on low and high power
the switch for low and high power the contacts are gone or you need to check the DC voltage to the output section and the voltage drop on TX usually the likes of the cobra 148GTLDX has a bridge board you can remove and add some LCD DVM for current monitors and setting of bias etc so perhaps a regulator has failed or a resistor or the contacts on the switch you need to trace it out using current readings
Apr 21, 2014 | Connex 3300 240-Channels Base CB Radio
My 1998 hitatci tv keeps blowing fuse whats wroung
The TV has two power supplies, low and high voltage. Most likely the high voltage transistor (called a Horizontal Output Transistor or HOT) is shorted due to a malfunctioning high voltage transformer (the biggest piece on the board with the large red wire coming from it. If the low voltage is bad most likely the diode pack (full wave rectifier) or the voltage regulator chip.
Remember fuses are to keep the unit from catching fire by opening up when a short circuit draws too much current. If you cannot replace the cause of the current draw, it's time to buy a new TV.
Feb 27, 2014 | Televison & Video
Area of solar cell for 1w
WOW time to get out the calculator.
That will depend on the output of your cell.
A WATT is voltage multiplied by current (amps X volts)
so you will need to know the size of your cell and the power output.
if the cell is 2cms X 2cms (which is about average) and the output is 100 Mil Amps
you will have 4 sq cms (area) and need 10 cells to make 1 amp - so you will have a total area of 40cms -- Ray
Feb 05, 2011 | Computers & Internet
How select low and hi power 1w and 25w
You didn't say which radio you have, but in general, there's a combination of the "function" ("F" or "FN") and another keyboard key (generally labeled PO or PWR) that will cycle through the outpower settings.
Jan 06, 2010 | Vertex Radio Communications
Kenwood TS 2000X: Low HF TX power output on HF bands ONLY.
Hello, this problem is solved and how?
I have the same problem on HF and VHF 30Watt max output
1.8 MHz-20M 0-5Watt
10M 25 Watt
6M-30Watt
2M-25Watt
70cm 42Watt is ok
23cm 10Watt is ok
thanks
Tuxon7@gmail.com
Jun 12, 2009 | Radio Communications
Very low TX output power on ALL HF BANDS ONLY. Other bands OK!
look for a broken or cracked board near the driver s & finals, try pushing around on the board with your plastic screwdriver, you may luck into it.
Jun 09, 2009 | Radio Communications
Low TX PWR/ATU won`t tune. No SWR and ALC metwr reading?
You've replaced the pre driver, the drivers and finals. Set bias and still low output. The pre driver is the same transistor used as the tx exciter transistor on other pcb chassis on bottom of radio. Follow the gray coaxial wire from the pre driver on the RF circuit board back to the tx/rx i.f. Circuit board. The gray coax cable plugs right next to the tx exciter transistor on this pcb. Again it's on a different pcb all together and on the bottom of the radio and also. Replace it! And check for open bias or emitter to ground chip resistor next to it. You will get your drive back. Very few rigs have I seen the actual Finals blown in the mosfet or the bipolar version. Just the driver stage with a week pre driver and the SMT "pre" pre driver on the same RF pcb. And the tx exciter on the other pcb.
Apr 24, 2009 | Computers & Internet
Icom Tait T2010 T2015 T2020 T2030 T2040 Radio Programming Software Cd Logo
101 people viewed this question
Top Icom Radio Communications Experts
peter0911
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
