Question about Kitchen Ranges
Bompani range cooker ignition switch not working
Ignition switch not igniting
  • 183 Answers
SOURCE: The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Posted on Jul 28, 2007
SOURCE: electrics not working
sounds like the board on the b ack where the main cable goes in,this happend to mine,very cheap to fix
Posted on Nov 24, 2007
SOURCE: Will not ignite
have a parkinson cowan renown model RG60SS, about 12 years old. automatic ignition does not work - no sound or anything.. please help!!!!!
Posted on Jul 07, 2009
  • 78 Answers
SOURCE: the ignition button not working on zanussi electrolux cooker
nope...there is no battery for ignition button sir..
thank u
Posted on Jul 18, 2009
SOURCE: I have a Rosieres Paul Bocuse range cooker but no
http://www.awardappliances.co.nz/content/RBC%20127%20USE%26CARE.PDF
Posted on Oct 05, 2009
Ignitor won't shut off
If you have constant sparking from the igniter, I would check for grease guild up in the ignition switch , arking across the contacts, I had that fault myself on another gas cooker , but be warned make sure power to igniter is off,
regards
pete
Nov 10, 2010 | Five Star TPN5107BW Gas Range
The igniter's aren't working on the surfaceof my RCA Gas Range
if the breaker is fine and the cooker will not ignite check to see if you have voltage at the spark generator if you do and does not operate check the switch what operates this if that OK then the spark generator at fault but when working on gas you should be a aproved gas engineer
Aug 21, 2009 | Kitchen Ranges
Ignition wont work, there is an electrical supply to the cooker
yes there will be a cooker switch located somewhere in the kitchen & from that there will be a supply to a cooker point witch is a white box that is no bigger than a single socket.
there should or should have been a 10mm heat resistant flex running from that to your cooker.
if there is a flex then your ignition mite run off a 3volt battery.check your manual if not then try this web site :
http://www.rangecookers.co.uk/installation-guide-content,MGQJD.aspx
Jul 02, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
Stoves panache 600 SIDLm
hi! first check your power is swithed on at the wall isolator. even thou its a gas cooker it will still need power for the spark!
Dec 20, 2008 | Stoves 600SiDOm Gas Kitchen Range
The ignition on our cooker stopped working after flash from rear
there usually is a unit at the back that is the ignitor i don't know on this model but it should have a fuse fitted to the igniter, its usually 3amp, check and see if it has blown this fuse. check it with another fuse and see if there is still a problem the fuse will blow if it gets a back feed. this could be form the switch that you push.
Jun 21, 2017 | Lofra MXUD66GGI Gas Kitchen Range
When i turn on the oven the top hobs keep clicking on my canon cooker
Hello Brian
Welcome to Fixya.
You said, when you turn on the oven the top knobs keep clicking on my canon cooker.
If you mean the electronic ignition keeps clicking when you turn the oven, It sounds like one of the switches that is controlled by the knobs, is stuck and malfunctioning! It sounds like it needs to be replaced.
There are 5 electronic igniter's on a 4 burner gas range, and the fifth is in the oven.
Let me know how you do.
Please remember to leave a rating when you finish.
Thank You, Huuum
Oct 02, 2008 | Kitchen Ranges
New World Classic 100 cooker
The closk and ignition is no longer working, how do I solve this?
Aug 27, 2008 | New World Ellingwood 100 (Gas) Kitchen...
Cooker lofra
fuse in plug new one job done + wife turnd oven off ?
Aug 18, 2008 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Will not ignite
Dec 30, 2007 | Parkinson Cowan SG340 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
