Question about Minolta DI2510 Black and White Copier
Minolta di2410 c0500 error code - Minolta DI2510 Black and White Copier
  • Minolta Master
  • 6,680 Answers
First ensure that the right side cover is closed correctly. Check that the two latches that are on the door are not broken especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can only use that paper clip for that only :) Copier tech humor!) Watch the screen you might see abort code that OK. When the screen come on that show the copiers look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing is going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again the machine will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code your messing with the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it.
Posted on Feb 07, 2015
firecontrol7
  • 6680 Answers
SOURCE: error message C0500
Take a paper clip and unbend it. Then stick it in the small hole on the right side of the control panel. The machine will say please wait. after a few seconds you will see a small blue dot appear on the left side of the contol panel, (about middle of the screen) when you see the dot press the down the "3" button a screen will appear, select "Trouble Reset" once done machine will go thur its normal procedure. Once you have ready to copy, turn off the machine agian and turn it back on, if you don't the start button will be flashing continuously, If code comes back then the fuser is shot (Fuser is the hot section of the copier. which fuses the toner to the paper.
Posted on Jul 19, 2009
firesnake09
  • 2923 Answers
SOURCE: ERROR CODE CO5OO FOR MINOLTA CS/PRO 2080 ????
This is a lamp error, check that is not burned, or the thermal fuse.
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Warning: Be advised that with fuser codes, some RISKS are involved, PLEASE SEEK PROFESSIONAL HELP to reduce these risks.
Thank you and good luck!
Posted on May 02, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: copyer minolta cs pro ep2080
This code means that you have a failure of a part in your fusing unit. The fusing unit is the assembly that gets hot and "fuses" the toner onto the paper. It is located right where the paper exits the copier. The most common part failure in this unit is the thermal fuse. As it's title suggests this part is a fuse which is suppose to blow if the fuser overheats. They usually just fail due to age. There are 2 other possibilities although not nearly as common as the thermal fuse. The other 2 possible failures are the thermister which reads the temperature of the unit and the heater lamp which actually provides the heat.
The thermal fuse is a cheap part at around $5.
You will most likely need a service person to come out and diagnose the problem and repair it. Unless you are mechanically inclined and have a service manaul you might have a hard time getting the fuser out of the machine and dis-assembled in order to replace the parts. There is also a specific reset procedure that must be followed in order to clear the C0500 from memory after repairs are made.
Good Luck and Thank You for using Fixya.
Posted on Sep 17, 2010
roytardio
  • 106 Answers
SOURCE: Konica minolta bizhub 3510 error
fuser problem or reset
Posted on Jun 13, 2011
babaprithi
  • 372 Answers
SOURCE: Minolta EP2080 malfunction detected ...
the laser unit of the machine is faulty.either the polygon motor in the laser unit is not working or the laser diode is not working.anyways u have to replace the laser unit to make it work and it is costly so better buy a new machine
Posted on Aug 16, 2011
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
C0500
May 01, 2014 | Minolta Di3510f Bizhub Copier
The machine di251f is saying contact your technician with code error c0500 please help
C0500: Warming-up Failure
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
Jun 17, 2011 | Minolta Di251 All-In-One Printer
Minolta error code c0500
A C0500 code deals with the fuser temp. You maybe able to reset the code, by pressing the trouble rest switch. If it will not clear you will need to look deeper into the fuser unit. I don't know what model you have, so I can not go any further. Good Luck
Nov 24, 2010 | Office Equipment & Supplies
Konica Minolta Di2510 error code C0500,can not reset error code
check the fusing unit parts heaterlamp,thermistor & thermoswitch i'm sure one of them is the cause of error c0500
Nov 22, 2010 | Konica Minolta DiALTA Di183F Copier
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
I am getting an error code C0500 after changing the toner. What do I need to do to get the printer back online?
Depends on the model of you Konica Minolta. The CO500 is usually related to fusing temp. It's possible that a power spike or a thunder storm that knocked out power to the building would caused this.
Jun 27, 2009 | Konica Minolta Office Equipment & Supplies
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
Minolta DI2510 Black and White Copier Logo
23 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
