My bush washing keeps making my fuse box trip
My washing machine is less then a year old I got it in argos put on a wash yesterday and it blew my fuse box now half way though a wash and cant use it
When I put my machine on to do a washing it blows my fuse box 8 mins into every washing cycle I select, It spins ,drains and rinses ok .So what can it be???????
Posted on Nov 07, 2013
  • 10 Answers
SOURCE: Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
it might be too small of a fuse for your machine
Posted on Feb 12, 2008
  • 333 Answers
SOURCE: My washing machine keeps tripping
Frequent tripping means a short in the machine. Disconnect from the supply and locate the drain plug somewhere at the bottom of the machine. You should be able to drain off the water and then open the door manually. Be prepared for a lot of water to be released. The fault will have to be fixed by a service engineer.
Posted on May 02, 2008
SOURCE: samsung washing machine - no power
checked internal wiring and found that when the machine went out of balance the counter balance on the top of the agitator drum had squashed the power wire against the the top rib of the frame causing the wire to short circuit and blow the power fuses to the house.
rejoined the power witr and relocated it above the rib frame so as to eliminate any further possibility of this happening again.
I believe this is either a design fault with the machine or it was incorrectly installed at the time of manufacture
Posted on Sep 10, 2008
  • 77 Answers
SOURCE: fuse keeps blowing out in my maytag washing machine
replace the complete lid switch ***'y. be sure to adjust properly.
Posted on Dec 03, 2008
SOURCE: LG WASHING MACHINE WM14225FD
My machine would not switch on this morning, no beeps or lights, I traced it to a small fuse on the main circuit board. you get to the board by disconecting from the mains, removing 2 crosshead screws at the back of the machine and lifting the top of the machine off ( once screws out, slide top of machine back about 1cm and then it just lifts off. You can now see the main circuit board, behind the control panel on front of machine. the fuse is hard to see and is solderd to the board on the lower left side, I solderd onto both ends of the fuseand replaced with a 10 amp HRC fuse, I still need to find the correct fuse rating, this worked for my machine.
However, and its a big however, If the 13amp fuse in youre plug blew and the trip on youre consumer unit, then I would imagine something big (pulling a large current) has gone down in youre machine to cause all these to blow, anyway hope this helps, Robin.
Posted on Dec 05, 2008
Hi 2 years ago I bought a BUSH washing machine model A1249RLB after having the machine for about 6 months the counter balance weight came off in the middle of a cycle destroying the machine I contacted...
my advice is simple if your disabled like me they contact your local reclimation yard center,,,, there are many across europe they will take your old machine away and provide you with a front loader machine refurbished i can help you via a local charity who will help too get it fitted email me at vsmlibs@talktalk.net i can help you source a machine locally for free exchange ...
this isnt good enough im sorry youve had to ask for help here!!
Mar 05, 2015 | Washing Machines
Washing machine wont work
If it's more than 6 years old, it's time for a new one. Or maybe you blew out your fuses. Try resetting the fuse box and switch off and on. Then after you switch back the power, go and try to turn on washing machine again.
Feb 13, 2015 | Washing Machines
My washing machine kkeps tripping my fuse box
This is related to a fault in the main control panel, it is possible there is a short if the fuse keeps tripping off. You need to remove plug and pull out the panel to check for short in the power supply to the main control panel usually a SMPS unit. Use a multimeter to check for short, if so this must be replaced.
check for tips from the link below:
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
Apr 30, 2012 | Hoover Nextra HNF 3157 Front Load Washer
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
I have a Bosch Exxcel 1400 S Express which blew
There is no internal fuse in the washer to replace.
If you have replaced the fuse, make sure that is is a good one.
If you are satisfied that you have power to the washer, then I'm afraid it sounds quite serious.
Trust this helps.
Dec 04, 2009 | Bosch Washing Machines
Kenmore wash machine will not spin
Eight years is getting kind of old. When the clutch or transmission goes out, it costs more to replace the part than to buy a new washing machine. You'd better plan a shopping trip rather than spring for that $100.
Aug 02, 2008 | Kenmore 22422 Top Load Washer
Hotpoint WD51 fuse issue
is it the motor that got hot?, if so then check the motor carbons for wear, as these heat up when worn, also if the carbons are fine check the pump and filters for blockages, this makes the motor spin while water is still in the machine causing the motor to overheat, and subsequently tripping and blowing the fuses etc hope i have helped a little
Sep 25, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Washing machine blown fuses
Hi - had a similar problem with about 3 different makes of washing machine - the RCD switch on the main household fuse box was continually tripping . Nobody could give me a right answer . Eventually ended up with a Hotpoint . Felt sorry for the delivery guys from the electrical retailers having to keep dragging machines in and out .
May 07, 2007 | Indesit WA 115 Front Load Washer
Fuse blew in plug
your main moter as a fault in its winding making it have a short which blows fuse
Jul 28, 2006 | Hotpoint WMA44 Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
