Question about SanDisk Sansa e260 MP3 Player
Sansa View not reconized by wmp
Device listed on menu but not available to sync music files.
  • lasmith1 Jan 28, 2009
    i cant download vidoes on my sansa sandisk mp3 player. I get videos from limewire then i dont know to download. I try to sinc but it wont work
  • 758 Answers
What i would recommend you to do is to uninstall the device and reinstall it uninstall it...assuming that you are running windows on start, right click on my computer and go to should have your system properties open then click under hardware then device manager...look for the sansa usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit... .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to and find the driver for your device..and then connecct the device on the back of your should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Posted on Jan 29, 2009
How do i transfer music from my sansa clip to my computer
Syncing and transferring music files to the Sansa player using Windows Media Player 10 How do I sync or transfer music files to/from my Sansa player using Windows Media Player?
STEP 1 - Connect the Sansa player to the computer
STEP 2 - Run Windows Media Player
1. Go to Start > Programs > Windows Media Player.
NOTE: If you can not see Windows Media Player on the menu, go to Start > Run then type WMPLAYER then OK.
STEP 3 - Sync files to the Sansa player.
1. Click the Library tab.
2. Drag the music files to be transferred on to the right panel.
NOTE: You can also right-click on the title of the song and select Add to sync list.
3. After creating the list, click the Start sync button to sync and transfer music files to your device.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | SanDisk Sansa Clip MP3 Player
I can not resync my sansa e270 when i plug it into the computer, i use rhapsody and never had this problem before
Hi, theres 2 ways usually to sync with sansa.
usually wen u plug it into the usb cord, u shud be able to open a folder and put musik through that.
My computers. than go to Sansa
or WMP depending on ur version
go to Synchronizing or Copy to CD or DEVICE.
there should be syncing button under the music list depending on the version.
but i stick to open my computer and the Sansa folder.
Go to ur Sansa in the USB option change it to MSC than follow these instructions
To add songs using the MSC mode, follow these steps:
1. Organize your songs into folders and place it into one directory.
2. Open "My Computer" and open the drive for your Sansa.
3. click on Tools choose File Option, there will be a Pop-up screen and choose View Tab
4. Select on Show Hidden files and Folder Option, so you can see all the files
5. Choose MUSIC Folder, double click and Drag and drop all the songs on that folder, and It will go automatically on your player. OR highlight a songs, right click select COPY, go to MUSIC folder right click then PASTE and it will be save on your Player
Good luck.
Mar 12, 2011 | SanDisk Sansa e270 MP3 Player
How do I download music to my Sansa Clip MP3 Player
First, you have songs into your computer. Then, plug the device to computer and use one of two ways to download music to your Sansa Clip:
1. Select songs you want transfer, drag & drop them into Music folder in the device.
2. Use Windows Media Player: plug device to pc, open windows media player, click on Sync tab, drag and drop songs selected to Sync List space (on the right side of wmp), click on Start Sync button to transfer.
Good luck
Jan 25, 2010 | SanDisk Sansa e260 MP3 Player
I cant find place to add music files to my player, SanDisk Sansa m240... I go to my computer open the files and find no music library
use windows media player... open WMP connect your player it should recognize it... use this to sync music to your highlight the songs in WMP right click ... go to add music .. select sync .. once you get the songs into a sync list ... you just sync the sansa...
Oct 16, 2009 | SanDisk Sansa m240 MP3 Player
Sansa e250 blue screen
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Nov 03, 2008 | SanDisk Sansa e200 MP3 Player
Files , I want to delete are invisible.. when searching device files...
It's kind of crazy, but here's what works for me (pain in the **** too). Some of the songs, you can see in explorer IF you set the MP3 player to Autodetect. The rest of the songs you can see if you switch to MSC.
So to be able to see all of the songs, I need to switch from one to another. I suppose that if I reformat the mp3 player (after having backed up all songs). Then I can choose just one mode to upload the songs.
I'm guessing that it has to do with differences with rhapsody, windows music player from XP and windows music player from Vista. But not sure.
Go to MENU>> Settings>> USB >> and switch between 'auto detect' and MSC.
Aug 18, 2008 | SanDisk Sansa m250 MP3 Player
Sansa View 8MB Player
delete and start over again
it's best to sync a few disconnect, let the database update, and then reconnect, load some more
Jul 12, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Do you know if windows media player recognized your device? if windows media player does, i would recommend you to format the device using windows media format your device have it connected and open up WMP,click on the sync tab the your device will be listed on the left side..then all you have to do is right click and format the device..that should work..
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
Can not view my music files on my laptop (but can on my desktop)
Get the latest firmware upgrade - this player wasn't originally designed with WMP 11 in mind. Also, make sure the laptop has the folders "My Documents" and "My Music" on it - this is primarily where WMP reads from.
Dec 06, 2007 | SanDisk Sansa c240 MP3 Player
Files on player are not listed in wmp or in windows explorer
change the settings of the player to MSC and connect the device to your computer. It will be detected as a removal disc drive. Open it and it should contain the folders in your player. IF you can only see a few folders. Click on Tools-Folder Option - Show hidden files and folders. Then you should see the folders that you have. Right click on the song and choose delete.
Aug 14, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
