Question about Cuisinart SS-300 Compact Single Serve Coffee Maker SS300
My cuisinart ss-300 compact single serve will not brew
I turn it on and the lights flash slow like normal so i fill the water add the k cup and click brew . here is where the problem lies it sits quietly like its doing something then the hot water and brew blue ligts start blinking rapidly . iv tried all the mends in the manual and none have worked. any ideas what the rapid blinking means?
I had the same problem. What worked for me was the paperclip trick. Yes, there is a metal puncture tube in the k-cup, but there is also one on the top of the lid (when you open it up as if you're putting a k-cup in there). I got a flashlight, used the paperclip to clean out all the encrusted grinds, put it thru the cleaning procedure with vinegar as per the manual, and now it works perfectly! Hope this helps.
Posted on Nov 06, 2014
3 Suggested Answers
Noggin
  • 944 Answers
SOURCE: cuisinart grind and brew coffee maker
here is the link to the manual; http://www.cuisinart.com/share/man/34_man.pdf ask again if you still haven't figured it out :)
Posted on Mar 15, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: instruction manual for cuisinart auto grinb and brew 1 to 4 cups
Here is the trick with the Cuisinart Grind n Brews - their proportion sizes are based on a 5 oz cup - most coffee cups are about 8 oz cups - so you really need to use more than they suggest, but here is their reccomendation:
We recommend you use 1 scoop of whole
beans per cup. Maximum 14 scoops.
For 1 or 2 cups, use 1-1/2 level scoops
per cup. Adjust the recipe according
to individual taste.
Posted on Mar 27, 2009
I have a cup o matic and it has recently started leaking from the main unit...???? Can I fix it?
you can if you can find where the leak is, and as long as it is just a worn o-ring and not a crack. You could contact Cuisinart for service? There are some articles on your particular problem in the main link at the bottom.
Pt 1: How To Use: Cuisinart SS-1 Cup-O-Matic Coffee Maker - YouTube
? 10:04
https://www.youtube.com/watch?v=jEPf5hXWkB4
Oct 18, 2007 - Uploaded by Jay Brewer
Learn how to use coffee pods and ground coffee with the Cuisinart SS-1 Cup-O-Matic Coffee Maker.
SS-1 - Coffee Makers - Discontinued - Cuisinart.com
https://www.cuisinart.com/discontinued/coffee_makers/ss-1/ Regular or bold, large or small - your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffeemaker, it's easy to brew your cup ...
[PDF]Cup-O-Matic™ Coffeemaker SS-1 - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/ss-1.pdf Cup-O-Matic™ Coffeemaker. SS-1. For your safety and continued enjoyment of this product, always read the instruction book carefully before using.
Amazon.com: Customer reviews: Cuisinart SS-1 Cup-O-Matic Single ...
https://www.amazon.com/Cuisinart-SS-1-Matic-Coffeemaker.../B000RIAIXO Find helpful customer reviews and review ratings for Cuisinart SS-1 Cup-O-Matic Single Serve Coffeemaker, Black and Brushed Chrome at Amazon.com.
Cuisinart® Cup-O-Matic™ Single Serve Coffee Maker - Bed Bath ...
www.bedbathandbeyond.ca/store/product/cuisinart-reg-cup-o-matic.../1014760199 Regular or bold, large or small, your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffee Maker, it's easy to brew your cup ...
Cuisinart Cup-O-Matic Single Serve Coffeemaker Review
www.goodhousekeeping.com/.../cuisinart-cup-o-matic-single-serve-coffeemaker-881/ Rating: 2 - ‎1 review
Unlike coffeemakers that only make a cup at a time, this model can be used with your favorite ground coffee as well as from coffee pods.
Single Serve Coffee Forums
cup matic leaking water Google Search
Sep 03, 2017 | Coffee Makers & Espresso Machines
Single serve flashes but does not brew
It's always best to give the model number of the appliance when asking questions about problems. Here's what a general troubleshooting procedure that might find the problem:
(1) Every once in a while an air bubble may get trapped in the water path. Lift off the reservoir, then put it back into place.
(2) Turn off and unplug the brewer for a couple of minutes or more. When you plug the brewer back in, be sure to turn the power back on.
(3) Make sure the water reservoir is properly in place, and perform a Rinse cycle.
(4) After placing the K-Cup® in the K-Cup® Holder, make sure the handle is pushed down securely and the LCD control panel reads READY. The and buttons, Brew, Hot Water, and Rinse buttons will be illuminated. Then press any of the lit buttons.
(5) If the LCD control panel indicates ADD WATER, check to make sure the water reservoir is properly filled. If not, add water. If so, make sure the water reservoir is properly seated in its base.
(6) If the LCD control panel indicates ADD WATER even after refilling and checking the base, contact Customer Service at 1-800-726-0190.
(7) The exit needle may be clogged (refer to page 19).
Sep 11, 2016 | Cuisinart Coffee Makers & Espresso...
How do I fix water leak in Cuisinart ss700 coffee maker
if Cuisinart is like my bunn they do not have parts to fix , it is throw away and buy new .
Oct 12, 2015 | Cuisinart SS700 SINGLE SERVE BREWING...
Why does my machine brew coffee very slowly almost dripping instead of brewing at regular cycle?
it might need cleaning solution to use is vinegar pour vinegar in it and turn it on let it fill the pot up hope this works good luck
Feb 26, 2015 | Cuisinart SS-700 - Single Serve Brewing...
My cuisinart single serve brewing system suddenly says "not ready" continually and I can't turn it off unless i unplug it. Same problem when i plug it back in.
Does't heat up or doesn't get the pressure? do you hear a pumping sound? if yes it means it doesn't heat, if not it means it doesn't pressurise...open it and check for spilled water, corrosion, disconnections.
Cheers
Nov 01, 2013 | Cuisinart Single Serve Coffee Maker...
Mr. Coffee single serve brewer won't brew
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
Sep 25, 2013 | Mr. Coffee BVMC-KG6 Single Serve Coffee...
Ss 700 single serve doesn't brew
Try smacking the top of it. (Not kidding)
Dec 24, 2012 | Cuisinart SS700 SINGLE SERVE BREWING...
Need instruction book for Cuisinart Single Serve Brewing System Model # CUISS-700
Here are the instructions to de-scale your Cuisinart SS-700, taken directly from the unit's manual, available here (www.cuisinart.com/share/pdf/manuals/ss-700.pdf):
1. Empty the reservoir.
2. Disable the AUTO OFF and OFF TIME features.
3. Making sure there is no K-Cup in the brewing chamber, fill the reservoir with 60 oz. of undiluted white vinegar.
4. Place a large mug on the drip tray and run a Hot Water cycle. Select the 12 oz. brew size. Discard contents of mug.
5. Repeat the hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
6. Let the Brewer stand for at least four hours while still on.
7. Rinse the water reservoir thoroughly and fill with fresh water.
8. Run another Hot Water cycle. Discard contents of large mug.
9. Repeat hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
10. You may need to perform additional Hot Water cycles if you detect any residual vinegar taste.
Note: If DE-SCALE is still displayed on the control panel after completing the procedure, repeat the de-scaling procedure above.
If you found this solution helpful, please leave a positive rating!
Sep 17, 2012 | Cuisinart SS700 SINGLE SERVE BREWING...
What does it mean when the brew light flashes?
Pot needs cleaning. Fill reservoir with 4 cups of vinegar. Press the SELECT button until the red CLEAN indicator light turns on. Let it perk through. It will take 45-60 minutes. It brews a few cups, stops and then should brew the remainder of the vinegar. When the cycle is complete the light will burn off and the coffeemaker will turn off. Discard vinegar solution and run a couple of pots of clear water through. Hope this helps.
Mar 25, 2010 | Cuisinart Cup-O-Matic SS-1 Coffee Maker
Condensation- Cuisinart coffeemaker DGB-300
The condensation is normal, not just with this Cuisinart Grind n Brew, but with ALL Cuisinart Grind n Brews - because of this, you will really need to clean it after every use if you want the grinder portion to last long. As far as the bean amt - Cuisinart bases it's reccomendations on a smaller-than-normal coffee cup size of 5 ozs or so. Plus, the condensation, as you mentioned, will prevent a certain portion of the grinds from flowing to the brew/filter basket. Add more beans or less water to make a stronger cup.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 16, 2009 | Cuisinart DGB-300 Coffee Maker
Cuisinart SS-300 Compact Single Serve Coffee Maker SS300 Logo
997 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
