What happened? When I first boot up on the black screen it tells me the battery is unable to be recognized and that it will only run off AC, http://www.accukorting.nl/hp-compaq-business-notebook-2710p.html . Then, my orange LED flashes incessantly and the battery does not charge.What happened?
  • 2,385 Answers
The battery gone out of order, needs replacement
Posted on Jan 22, 2013
SOURCE: hootoo
laptop accessory
Posted on Mar 09, 2010
sales99521
  • 62 Answers
SOURCE: Is buying this Hp Compaq 6910p Battery a wise decision?
I have bought a couple of batteries from them before. They work just make sure that the voltage of the battery. (10.8v) matches the voltage on your battery. Also make sure that the mah 6600mah is greater or the same as the battery that you have. The mah is the mili ampers per hour (in other words the fuel) the bigger the mah the longer your battery will run. I also find ebay a great place to buy hp batterys from. Just make sure that they are oem hp and not a generic knock off and you will be fine and use the same rules from above. and also make sure they will fit your model number. I hope this helps
thanks
Steven.
Posted on Apr 24, 2010
nagprasad
  • 8 Answers
SOURCE: where can i buy the cheap HP Compaq 6710b
You can buy in best buy mall.
Posted on Nov 12, 2010
  • 5 Answers
SOURCE: fit my Compaq Presario CQ61?
accu Compaq Presario CQ61 100 percent compatible with you Compaq Presario CQ61. I bought two Compaq Presario CQ61 batteries from http://www.accukorting.com/compaq-presario-cq61.html two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Posted on Nov 30, 2012
  • 5 Answers
SOURCE: Fit my HP EliteBook 6930p?
accu HP EliteBook 6930p 100 percent compatible with you HP EliteBook 6930p. I bought two Compaq Presario CQ61 batteries from http://www.accukorting.com/hp-elitebook-6930p.html two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Have a compaq presario running win 7. The system does not recognize when it is running on ac power (original ac adapter). The battery charges but the only sign of this is the battery icon says xx%...
Hi, it seem as if your battery is faulty you should try another battery to see if the computer will recognize when it is charging, you can also try your battery in another compaq presario computer to see if it will have the same problem.
Aug 02, 2010 | Computers & Internet
Computer was on AC power. Left unattended it shut down. Would not wakeup. Shut down fully, it would not come back up. Get a 2 short beep code. Invites an F1 to go to setup. Won't go to setup. Screen then...
Can you tell if your AC power cord is working? (Is there a light on the computer that comes on when it's charging?) If the power pack went dead, your battery could've died and now you get no power to the PC which is why it won't boot up.
To test, take out the battery and plug the AC cord in and try to boot up. If nothing at all happens without the battery, then your power cord or power pack is dead, and you just need to replace it.
May 29, 2010 | IBM ThinkPad T21 Notebook
Black screen on boot up- I tried to start my asus1005HA-PU17 and got only a black screen. After leaving it for a few hours it started-why?
Try draining the flea power first:
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
Check if it will load to windows, if not, there could be a problem with windows. Try startup repair on advanced boot options. Hope this helps.
Mar 22, 2010 | Computers & Internet
My IBM T40 boots to a black screen with the "z"(light at top to right of power.
Try these steps:
1. Remove battery and unplug AC adapter
2. Press power on button for 30 seconds or so (one min is also too)
3. Attach battery and plug into wall
4. Power "ON" as normal
If you are still getting the "Z" and a black screen then I would have the video card or hard drive looked at and replaced. Start with the video card and then look at the hard drive
thinkpad-t42-wont-boot.html">http://www.techsupportforum.com/hardware-support/laptop-support/234433-ibm-thinkpad-t42-wont-boot.html
Feb 17, 2010 | IBM ThinkPad T40 2373 Notebook
Will not boot... black screen?
Try removing the battery completely and powering it up on AC power. Sometimes a dead battery (even if you're plugged in to AC) will stall a boot-up in its tracks. If this doesn't help, please reply back and let me know if anything changed.
Jul 09, 2009 | IBM ThinkPad T40 2373 Notebook
Pc will not come on. Runs Hot. Will not click off.
have you tried to remove the battery and disconnect the ac-power?
then reinsert the ac-power (without battery)
and try to boot.
if that doesnt work:
remove battery and ac.
turn computer upside down. under one of the lids there will be 1 or 2 memory modules (ram). take them out
insert ac
try to start the computer (yes, without the ram modules)
leave the computer on (with black screen) a couple of seconds.
remove the ac
insert the ram again.
insert ac
try to boot again.
May 29, 2009 | Acer Aspire One PC Notebook
AC adapter not recognized
If you don't get any errors when you startup on battery then all you have to do is call Dell. Get work order number and send them the laptop and adapter. They are very fast. I sent a laptop to them last month and I had it back in 3 days! I was surprised.
Dec 04, 2008 | Computers & Internet
Can't start my computer
does the monitor is getting on....do you see anything in the monitor?
Mar 05, 2008 | Computers & Internet
I was installing a program, and the screen went black adn the system shut down.
remove battery and try ac-power if laptop boots up then battery need replacing but if no laptop bootup then take it to be repaired and tell the tecnition what happened and he or she will try other options to get you going again. good luck on problem.
Aug 14, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
