Question about LG WM1814CW Front Load Washer
My washer has suddenly reading error code oe, read thru the manual and followed the directions and is still giving me the code? HELP!!!!!
I HAVE DRAINED IT SEVERAL TIMES AND CHECKED FOR ANY OBSTRUCTIONS, ALL CLEAR. RAN A QUICK CYCLE STILL STOPS AT 18 MIN AND SITS AT THIS TIME FOR SEVERAL MIN AFTER THEN GIVES ERROR CODE OE.
    Problem Solver:
  • 14 Answers
Replace the drain pump
Posted on Jan 25, 2013
SOURCE: Front loader LG Washer
opened the little door at the bottom of the washer in the front and used the little hose to drain the washer into a pail and then removed the filter beside it and cleaned it out then all was fine. life was good!
Posted on Jul 11, 2008
SOURCE: LG WG3431HW OE Error: Rattling & Not Draining.
water will not drain says oe
Posted on Aug 08, 2009
MNTECH
  • 1543 Answers
SOURCE: i have a lgwm 2677hbm washer and got a code read
It is not likely an object got past the filter before the pump, so I'd guess that the impeller has come loose from the pump motor shaft. Replace the pump motor. (washer will not spin if water is still in drum)
Posted on Nov 06, 2009
  • 56 Answers
SOURCE: WM2487HRM goes thru the wash cycle then gives OE
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
Posted on Feb 12, 2010
  • 552 Answers
SOURCE: My LG WM2487HRM has the
The pump is on the lower left of the front
Posted on Mar 08, 2011
Janome 9000 giving this error and not proceeding
Sorry can not read Japanese symbols . I would contact Janome direct thru their website . http://janome.com/en/support
Feb 22, 2016 | Janome Sewing Machines
WASHER DISPLAYED "OE" NOW IT WILL NOT DO THE SPIN DRY
Hi there, my mum actually had that problem with her LG washing machine, we did clean out all the drains and hoses just like you did, and also checked the pipes for any damages(cracks/ bends). Turns out the cause was that the machine just wasn't sitting level, so it wasn't draining out properly. Water just collected inside the front of the machine causing that error. Check if the machine is level, and while you're at it check your filter for clogs.
Mar 08, 2014 | Kenmore Washing Machines
How to fix error oe?
OE is drain error. Clean the pump out. Error codes and directions are in the MANUAL DE SERVICE on my foggyfacts blog amigo.
Jun 12, 2012 | LG WM-2277HW Front Load Washer
Have an LG washer displaying an OE code what could be the problem
An OE error code means that the washer is not draining properly. Pull the filter out at the bottom left corner to make sure that the filter is not plugged with debris. Read your manual before pulling the filter out so you don't flood your room.
Good luck.
May 28, 2011 | LG WM-1832C Front Load Washer
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Sep 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Gives message...oe
On pg 18 of the service manual for this combo, front-load LG washer/dryer, it basically says if the drain's not working and you see an OE error code, clean the drain pump filter and retry. So first do that.
http://www.retrevo.com/support/LG-WM2277H-Washers-manual/id/438ag213/t/2/
Manual above.Below is a great DIY self help washer site, use with manual to sort your problem out.
http://www.washerhelp.co.uk/diy-repair-help.html
Jun 18, 2010 | LG WM-2277HW Front Load Washer
It is not completing the cycle and flashin oe on the time screen its a lg wm 14336fdk
hello
The "oe" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while "oe" error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the "oe" error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Washing Machines
LG WM1814CW Front Load Washer Logo
182 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
