Question about Dryers
OF or DF error code on Hoover Hydro Dryer HHD780 UK
Dryer will switch on but will not do anything after this Door is properly closed Internal light comes on
  • 686 Answers
SOURCE: Dryer won't come on
and also change your cycling thermostat if your thermal fuse is bad chances are the thermostat is bad too
Posted on Mar 12, 2009
Greg20
  • 149 Answers
SOURCE: kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Posted on Jun 12, 2009
  • 172 Answers
SOURCE: control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Posted on Aug 12, 2009
SOURCE: After switching the door on my AEG Lavatherm T500
The door may have loose screws on the metal to plastic frame, try holding the door in at the top middle
Posted on Nov 20, 2009
  • 949 Answers
SOURCE: Dryer won't start, checked thermal fuses and start switch.
It sounds like you have been through most of the areas too look.
One thing to make sure of is that you have a full 240 volts. An electric dryer can measure 120 volts. from L1 to common and 120 volts from L2 to common but you also need to make sure you have 240 volts from L1 to L2 on the meter, one leg of the breaker or one of the two fuses could be blown.
If this is alright you only have a couple components left. The timer contacts and the drive motor. Either of these could be causing the issue.
To check the motor with the power disconnected check for continuity between switch terminal 5 and the Green(black) wire on the motor. If you have no continuity the motor is bad. Check for continuity between the terminal 6 and the yellow wire on the motor, if you have no continuity there the motor is bad. Check for continuity between terminal 1 and 2 on the motor if you you do not have continuity the motor is bad.
The timer should have continuity between the Yellow and Grey wire terminals for the motor to start.
I hope this helps
Posted on Apr 23, 2010
Testimonial: "Great advice, thank you for your help."
Tip
Samsung dryer error codes
Samsung Dryer Fault Codes
ts Thermistor shortCheck for restricted vent. Replace thermistortoThermistor openCheck for restricted vent Replace Thermistor
do Door OpenCheck connections. Replace door switch.
FE Power Source Frequency errorCheck power source
dF Door circuit failureCheck wiring to door switch. Replace door switch
hE Heater errorRestricted vent. Replace thermistor.
bE Button ErrorCheck and / or replace PCB
od Over drySensor Bar open. Adjust time up excessively.
Et eeprom failureReplace Eeprom
on Apr 14, 2015 | Dryers
Reason for door codes on a frigdaire front load dryer
Assuming door seal is good, make sure there is nothing "caught" under the seal that prevents the door from closing properly. Otherwise, look for anything else that would contribute to that issue. Possibly the door switch that turns on the interior light and acts as a safety for a door open situation may not be operating properly. See my "generic" tip for "buzzing" dryer issues.
Mar 03, 2015 | Frigidaire Affinity FAQE7011LW Electric...
Error code e61
Identification
  • GE dryers use three-character codes that display on LCD screens. Every code starts with "E" and is followed by a two-digit number.
Power Failure
  • When your home loses power, the "E01" error flashes on the screen. Reset the dryer memory by unplugging the device, waiting 30 seconds and plugging it back in. The error code will disappear.
Thermistor Errors
  • Errors "E02," "E03," "E04" and "E05" are thermistor errors. The thermistor, when operating properly, reads the temperature of the dryer. Errors E02 through E05 indicate the thermistor must be replaced.
Effects
  • When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
Control Board Errors The control board sends signals from the controls to the dryer. When this fails, errors "E61," "E80" and "E81" appear. Contact GE service or install a new control board for the dryer
Jan 15, 2013 | Electrolux Dryers
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
Heater not working
The model that you provided is not found. Usually the model number can be found if you open the dryer door and look around the housing
http://www.on-timeapplianceplano.com/dryerrepair.html
Jul 23, 2012 | Hoover Dryers
Hoover Nextra HNWF 3135 door will not lock
1) test the switch door, you do not have error code.
see the video, and replace for defective switch, or loose wires or broken, or burn.
God bless you
Jun 28, 2012 | Hoover Nextra HNWF 3135 Front Load...
Dryer not working. Lights reads PF
If your dryer is showing code PF, then a power failure interrupted the previous load from completing and you will need to restart the cycle. You will need to press and hold the "Start" button to restart. If the error message reads E1, E2 or E3, then there is a more serious problem and a technician will need called to resolve the problem.
Kenmore dryers come equipped with door switches. If the door is not closed entirely, the dryer will not start its cycle. If the other indicators seem in working order and the door is properly shut, the door switch may be faulty. On some models of Kenmore dryers, there is a warning light to indicate if the door is open. If the "Door Open" light is still lit when you have closed it and heard it click, you should look into replacing the door switch.
Another possibility is the thermal fuse. This fuse is usually found in the back panel near the exhaust duct. If the dryer overheats, the thermal fuse will blow, shutting down operation of the dryer until the fuse is replaced.
Check the wiring from the outlet. If you have recently had to convert from a four-prong wire to a three-prong wire, or vice versa, the connections to the dryer may be faulty. Make sure that the red and black wires are connected to the proper hot terminals, the green wire to a ground and, if present, a white wire to the neutral connection.
Thanks and have a nice day.
Jul 04, 2011 | Kenmore Elite HE4 Electric Dryer
Hoover washer/dryer VHW854D SHOWS ERROR CODE E11. Machine switched off and door opened. Wash cycle had not started. Door closed and machine switched on and all works OK. Any ideas?
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Dec 20, 2010 | Washing Machines
Filter?
The 'check filter' is just a reminder. It is on when you turn the unit on, and at the end of the cycle.
The blinking lights, every 1/2 second is not, it is an error code. It is telling you that there is a problem with the door switch (light switch). It could be a loose wire or maybe the door is not shutting properly. Unplug the unit, take off the lid and check the connection. Replace if necessary.
Sgt 48
Oct 15, 2007 | LG DLE2512W Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
