Question about Tag Heuer Aquaracer Quartz Chronograph CAF1112.BA0803
Second hand is not moving - Tag Heuer Aquaracer Quartz Chronograph CAF1112.BA0803
Second hand not moving
If the Chronograph is running, the second hand may be paused as on of your dials is recording seconds instead of the larger second hand. You shouldn't be running the chronograph timing all the time.
Jan 13, 2016 | Watches
My invicta reserve second hand does not move
Very often not the second hand, but the seconds hand for the stopwatch. If you are sure it is, then try pulling the crown out, moving the minutes hand and then resetting the crown.
Dec 27, 2015 | Invicta Watches
WHY DOESNT THE SECOND HAND MOVE?
It probably isn't the second hand, but the sweep timer hand that is only used in Chronograph mode. If it is indeed the small second hand down at the bottom of the watch face, try pulling the crown, and moving the hands and then depress the crown again.
May 10, 2015 | Oakley 12 Gauge Chronograph Stainless...
The seconds hand on my invicta subaqua reserve does not move. It only moves when I start the chronograph. I've read the instructions time after time and can not get it to work.
The hand that moves when the chronograph is working is not a second hand. It will rest at the 12 o'clock position unless you are using the stopwatch. If your Invicta has a second hand, it is one of those small dials on the watch face.
May 03, 2015 | Invicta Watches
Second hand is stopped, hour hand moves in oposite direction, behaves like second hand.
Peet you need to take it to an expert to fix this problem. The watch is complex. save it.
Dec 08, 2013 | Casio Edifice Watches
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Seconds hand not moving
The roles haven't been reversed. The seconds hand for normal timekeeping is the small one and the chronograph timer seconds hand is the large one. The reason for that is that it is much easier to determine the precise second with the larger hand. It working exactly as it should. If you like having the large second hand moving all the time you will not hurt the watch by leaving it running. All chronographs work this way. Nice watch - wear it well!
Apr 29, 2010 | Swiss Army Wenger Commando 70725 Wrist...
Second hand moves three seconds at a time
You have to replace capacitor in your watch. After that it will run like new.
Jan 03, 2009 | Seiko Kinetic watch
The second hand is not moving
make sure your mode is on time and not calender. if on calendar it sticks on the present month and does not move.
May 24, 2008 | Watches
Tag Heuer Aquaracer Quartz Chronograph CAF1112.BA0803 Logo
27 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
