Question about Dell Precision Workstation 490 - MT - 32bit Dual Core Intel Xeon Processor 5120 1.... PC Desktop
Dell 490 Unable to initialize Fan Controller - Dell Precision Workstation 490 - MT - 32bit Dual Core Intel Xeon Processor 5120 1.... PC Desktop
    Habit-Forming:
    Scholar:
  • 186 Answers
This issue can be resolved by disconnecting the AC power cable from the system and draining the power from the system by pressing and holding the power button on the front of the chassis. (Approximately 30 seconds). Reconnect the AC Power cord and restart the system, issue should be resolved
link
http://stuartconnections.com/products/Computers/Systems/Desktops/Dell/Precision_690/Users_Guide/tools.htm#wp1056136
Posted on Oct 21, 2016
3 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: dell precision T3500 unable to initialize fan controller error
Step 1:
b> WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Every computer comes with its own internal cooling system. Dell workstation desktops are no different. Your computer's cooling system consists of a heat sink and cooling fan. The function of the cooling fan is to regulate the temperature of your computer's processor. If the fan stops working your processor will overheat and cause damage to your motherboard. Fortunately, Dell desktops have a built-in alert system that tells you when your fan stops working.
Shut down your desktop computer. Disconnect the power cable from the computer's back panel. Then disconnect any external devices. Rotate the computer so the back panel is facing you. Attach an electrostatic discharge (ESD) strap to your wrist and its wire clip to the outer casing of the computer. Lay the computer tower on its left side. Press on the side panel release buttons situated on the top and bottom panels. Grasp the side panel and rotate it away from the computer until the internal contents of the computer are accessible. Locate the cooling fan duct near the center of the motherboard. Lift the duct off of the cooling fan so it is in the upright position. Disconnect the fan's power cable from the motherboard. Disengage and remove the retaining clips from each side of the cooling fan assembly. Lift the cooling fan out of the motherboard. Set it aside. Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Use a clean paper towel to wipe the excess thermal grease from the processor's surface. Apply a thin coat of thermal grease to the processor's surface using a cotton swab. This is important; if you skip this step, your processor will fry as soon as you power on your computer. Place the new cooling fan over the processor. Press down on each retaining clip until the cooling fan snaps into place. Connect the fan's cable to the motherboard. Place the air duct back over the cooling fan assembly. Rotate the side access panel downward over the computer's opening. Press down on the side access panel until it snaps into place. Place the computer vertically, and then reconnect all cables and devices to the computer.
Posted on Feb 18, 2013
butaqa
This works without opening the case. It should resolve your problem:
1. Shut down your Dell Precision T3500 workstation.
2. Disconnect the AC power cable from the system.
3. Drain the power from the system by pressing and holding the
power button on the front of the chassis for about 30 seconds.
4. Reconnect the AC Power cord.
5. Restart the system.
Issue should be resolved.
- Source = Dell Support:
http://www.dell.com/support/article/us/en/19/SLN79964/EN
Posted on Mar 21, 2016
Dell precision T3500 unable to initialize fan controller error
Step 1:
b> WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Every computer comes with its own internal cooling system. Dell workstation desktops are no different. Your computer's cooling system consists of a heat sink and cooling fan. The function of the cooling fan is to regulate the temperature of your computer's processor. If the fan stops working your processor will overheat and cause damage to your motherboard. Fortunately, Dell desktops have a built-in alert system that tells you when your fan stops working.
Feb 18, 2013 | Dell Precision T3500 Computer Workstation...
Dell precision 490 led 1 & 4 on
If you are getting no video at all, then we can use the diagnostic LEDs and the power LED to help determine the failure.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Mar 29, 2010 | Dell Precision Workstation 490 - MT -...
Ati or nvidea? which is more reliable and well built for dell
To me it is probably personal preference. I have always like Nvidia, and I have had a couple of systems that had ATI. Nvidia to me seems more stable and more reliable. You might search some sites for benchmark comparisons
Jan 02, 2009 | Dell Precision Workstation 490 - MT -...
Fan noise
I was having the same problem and I just fixed it yesterday. You will never guess what was causing the loud fan noise.... give up? the NVIDIA Quadro Graphics Cards that were in there...... I bought an ATI Radeon 3870 yesterday popped it in, installed the drivers, and now my computer does not sound like an airplane anymore....... this card is amazing and its on newegg now for 80 bucks..... itds GDD4 as well and the games look better than a playstation 3........ this card also improved my overall system performance drastically.....
Dell Precision 490 constant reboot after ghost image completed
Hello-
I figured out how to ghost a Dell Precision 490 with a 32 bit Windows XP Image! Like you I had the same problem where it would constantly reboot after I imaged it with an existing 490 image. The answer is actually very simple. Boot up your Precision 490 and hit F2 to enter the bios. Select Drives and then SATA Operation, change it to "Raid Autodetect / ATA". Reboot the 490 and re image the machine, it will now work!
Dec 01, 2008 | Dell Precision Workstation 490 - MT -...
Error code sc 490 and sc360
Did you try to rest the error? Do you know how too?
Feb 09, 2008 | Ricoh Aficio 450 Copier
Dell Precision Workstation 490 - MT - 32bit Dual Core Intel Xeon Processor 5120 1.... PC Desktop Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
