Question about Fujitsu 50 in. Plasma TV
Fujitsu 50" plasma has buzzing from panel, loud. Present when sound mute
2 Suggested Answers
SOURCE: fujitsu 50"plasma TV
Not yet solved the problem, I have replaced the Arial and cable but still loosing sound occasionally, not as often as before. Maybe it is the LG HDMI receiver.
Posted on Mar 17, 2007
No sound on my fujitsu 50" plasma TV
its not hooked up right your cable box or tv manual should show you how, cable audio out, tv audio in left and right
Jun 15, 2013 | Fujitsu P50XHA10 50 in. Plasma Television
The sound is FULL BLAST even if it's on zero or mute. LOUD is the only option.
sounds like one of the buttons is stuck down on the control panel this will cause the other buttons to be inoperative
Jul 15, 2012 | Hitachi Ultravision P50S601 50 in. Plasma...
Brand new Panasonic TC-P50ST30. Probably 100 hours on the device. Only within the last two or three days have I begun to hear a very loud buzz coming from the back of the television. I have, of course,...
Sounds like my TV did before it stopped working. Ended up being the TV ground Arcing across the screws that hold the board down. There was a bulletin (https://www.badcaps.net/forum/showpost.php?p=423440&postcount=57) on it but you may want to remove the boards and check for marks before any components get wrecked. Make sure that if they are blackened/etc you clean them and tighten the screws down good and tight. Hopefully this helps.
Apr 04, 2017 | Panasonic Viera TCP50ST30 50 3D HDTV...
A buzzing noise coming from inside the tv but still buzzes when on mute but doesnt buzz when tv guide is up on the screen or when a channel is showing what time it starts
plasma tvs buzz a lot, depending on screen brightness. its probably normal but if you can hear loudly over your volume, may be a bad board or plasma panel. from behind tv, left side = y board, right side = z board, middle = power board ---- bad panel can buzz from anywhere... if you hear all parts buzzing, its probably normal plasma noise
Jun 01, 2010 | Samsung Televison & Video
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
Buzzing/humming sound from rear of TV unaffected by volume settin
Hi.
I think you have problem with the main digital PWB
You need change that part.
Nov 18, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Humming/buzzing sound
We usually find this is the cabinet back rattling. To confirm, when this happens turn the volume on the set all the way down and see if the problem is still there. If it is still there the put your hand on the back of the tv and gently press to see if the buzzing goes away. If the sound does go away the cure is to loosen all of the back cabinet screws around the edges of the set and gently push on the back as you tighten the screw. tighten the screw in an order much like you would tighten the lug nuts on a tire. in other words thighten the top left screw, then the bottom right screw and kepp alternating as yougo around the dabinet back untill they are all tight.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 23, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Fujitsu  50 in. Plasma TV Logo
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
