Question about HP Compaq nx9030 Notebook
2 HP compaq nx9030 laptops which failed bios hard drive test
One gave a failed code of 7
one gave a failed code of 4
Do I have to replace both hard drives, or is there any underlaying issues here?
Forgot password Hp nx9030
Windows access? Bios? hard drive? Which???
Aug 29, 2014 | HP Compaq nx9030 Notebook
My hp nx9030 keep rebooting itself with the message, PXE E61 media test failure check cable, PXE -MOF EXITING PXE ROM.what can i do
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 26, 2011 | HP Compaq nx9030 Notebook
371796-001 HP nx9030 heat fan works when tested
go to bios settings by pressing F10 for hp .. there select the optimal factory defaults.and engage and also save settings with F10 ...and exit ..This will get rid of any wrong settings made in bios ..related with he fan ..and should start proper..The only thing that can malfunction is caused by a higher temperature to start ,, and never get to it ..
If it still makes the same ..you should consider changing it ..or see the wires to be proper inserted..cause it has 2 for power and one for starting..and can be damaged..but still functional when you check it ..just the wire for the start to be damaged or not making contact .. ..
May 24, 2011 | HP Compaq nx9030 Notebook
How to remove my hard disk from HP Compaq nx9030
you have it explained in this manual from page 93 to page 97. It's very easy, but be careful when you remove the hard drive conector, if fits very hard to the HD...excuse my english.
Aug 26, 2010 | HP Compaq nx9030 Notebook
Problem with hp compaq nc8430 no see my hard drive Went I reinstall windown xp my hard drive it not present
Go into the BIOS setup (press f10 during boot process), then SYSTEM CONFIGURATION and disable SATA NATIVE SUPPORT. Try installing XP again and it should see your hard drive.
(If it will work then please vote for me).
Thanks
May 17, 2010 | HP Compaq nc8430 Notebook
The bios test of hard disk test is failed wht can i do now
If the hard disk has failed, and you want the data off of the hard disk, you have two choices..
Purchase a extender to allow you to read the hard disk and also purchase a data recovery program to get the data off the hard disk...
Or google data recovery service and find one that can retrieve data of of bad hard drives..
Either way afterward you will need to purchase a new hard drive.. They have drives as low as 30 dollars online that can be purchased and then installed.
You will need to reinstall windows on the new hard drive you get..
Ultimately you will have to weigh the cost of repairing the computer ( purchasing a hardrive and purchasing a new copy of windows)
Versus purchasing a new computer.
Oct 31, 2009 | HP Compaq nx9030 Notebook
On my lap top i receive message-"error loading operating system"
Trying booting into safe mode by pressing F8 while the computer is booting up.
Choose safe mode with the arrow keys and see if it boots that way.
Mar 20, 2009 | HP Compaq nx9030 Notebook
How to fix Hp slimline Error Code BIOHD-5
1. Restart the computer.
2. Keep tapping the F10 key when the Compaq logo appears. BIOS Setup Utility.
3. Select the Diagnostic tab.
4. Select the "hard drive self test" option and press enter to perform the test. Note: This test takes atleast 40 minutes. This will take you to
Pass - The hard drive is not damaged.
Fail - The hard drive is damaged and may need to be replaced.
Mar 09, 2009 | Computers & Internet
HP Compaq nx9030 Notebook Logo
514 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
