Question about Northstar POWER/DATA CABLE FOR EXPLORER 650 657 660 M84 M121 Model # CB000125A-G
Pin layout for northstar m121
Ais connections
How do I fix screen on Northstar 951xd?
I have the same problem and am about to buy a display from Mavin.com. This is on the product page for the display:
**Note that this is not a direct replacement for the Northstar,but with some soldering it can be made to work.It is the same screen as used in the NorthStar units, it hasdifferent connectors. What this means to you is that youwill need to solder the connections directly to this board.Once connected, it works just fine.
Aug 13, 2015 | Northstar 951XD GPS Receiver
F5TF-19B132-BA Ford Radio Pin out
The stereo pin layout can be obtained from the car dealership, also a repair manual should have the stereo wiring harness layout in it , the stereo harness adapter for installing non oem stereo, found at the local auto parts store will come with the wiring layout, wires are color coded too, sometimes the stereo harness or stereo harness adapter will have small writing on the wires itself, showing you what that wire is for, and where it should connect.
Basically it comes down to, obtaining the stereo wiring layout, read the description on the wires, and properly connect them together, then solder the wires or crimp them, I like to solder mine with soldering wire for electronics, and put shrink tubes to protect the wires, put the shrink tubes on the wires before soldering together, and ensure the shrink tube is the proper size awg wire gauge.
You will also need, aftermarket face adapter kit and antenna adapter, if installing aftermarket stereo.
Hope this helps and enjoy the stereo :)
Apr 11, 2015 | 1999 Ford Taurus
CRT VGA cable pin color problem. I can not get which pin connect where
Refer its connection diagram. The user manual might help you. If not, contact any service technician.
Nov 25, 2014 | Philips Televison & Video
We have a Northstar system on our boat...the M121 and while out fishing today the screen went so dark we cant read it without a flashlight. Cant seem to be able to fix it either..any ideas?Thank-you
i have the same problem there is a resistor on the high voltage side burned cannot identify the number or resistance to replace it need diagram or parts list for machine
Jul 30, 2013 | Northstar M121 Navigation System
Colour codes of output data cable explorer 650
From the owners manual (page 78, link below) NMEA out (+) is the white wire and NMEA (-) or ground is the black wire.
-Steve
http://www.northstarnav.ca/upload/Northstar/Documents/EXPLORER_650.pdf
May 14, 2012 | Northstar POWER/DATA CABLE FOR EXPLORER...
'Turn off power and reinstall the jumper in normal mode'
go to this site to visualize the motherboard layout as i'm about to describe below. Refer to pages 12-13 http://www.intel.com/assets/pdf/prodspec/dg31pr-tps.pdf
Note: Make sure to shut down your PC and unplug from power source.
- Look for Bios Setup configuration jumper block (the one marked X on the motherboard layout)
- You will see 3 pins with a jumper connecting 2 of the 3 pins.
- Ensure that the jumper is connected to pins 1-2 to set it to Normal mode
please refer to page 53 of the pdf file to check the pin configuration of the jumper block.
Jun 22, 2009 | Intel DG31PR Motherboard
Dell GX270 SATA front panel 34 pin layout
if you are talking about connecting the front chassis connectors to your motherboard then you need to find out the exact model of the MB... im assuming its Intel since its a Dell.
the link below should get you started
http://www.intel.com/support/product.htm
Jun 01, 2009 | Dell OptiPlex GX270 PC Desktop
Bushnell Northstar 78-8840 Pinouts
Here is a web site with all the manuals for Bushnell telescopes -- possibly the pin outs are described in the manual for your telescope?
http://www.opticsplanet.net/bushnell-warranty.html#manuals
Apr 10, 2009 | Bushnell NorthStar 78-7880 (190 x 78.74mm)...
Northstar POWER/DATA CABLE FOR EXPLORER 650 657 660 M84 M121 Model # CB000125A-G Logo
59 people viewed this question
Top Northstar Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Northstar Boating Expert? Answer questions, earn points and help others
