Question about Car Audio & Video
I have an 08 VW rabbit and I believe the stereo fuse was blown. I pulled it out to replace with after market radio but because I was missing a cable, I had to put it stock radio back in.. But it didn'
I have an 08 VW rabbit and I believe the stereo fuse was blown. I pulled it out to replace with after market radio but because I was missing a cable, I had to put it stock radio back in.. But it didn't work! While doing all this, a spark blew up because yellow and black cables touched. Hope this can be a good description! Thanks.
    Problem Solver:
  • 8 Answers
When the spark occured you might have blown another fuse. My advise would be to check all the fuses before trying anything else.
Posted on Jan 22, 2013
How do you check fuse in the back of the radio?
1.Turn off the vehicle. Locate the main fuse box.
2.Locate a fuse box that isn't under the dashboard by checking under the hood of the car.
3.Look at the diagram on the inside of the fuse box's cover.
4.Determine if the fuse is blown by looking through the clear plastic casing.
5.Take the blown fuse to an electronics store or a car-parts store.Push the new fuse into the empty slot in the fuse box, making sure that it is in the same direction as the other fuses. It should slide in with a tight fit.Replace the fuse-box cover.
6.Complete the above steps before removing the car radio.Disconnect the car battery under the hood by disconnecting the cable from the negative terminal (the black cable) of the battery. Remove the dash area around the car radio.Unscrew the four screws on each corner of the car stereo.Locate the fuse on the back of the car radio.
7.Take the blown fuse to a car-parts store or electronics store to find a replacement fuse. Place the new fuse into the car radio.lide the car radio back into the dash opening. Replace the corner screws followed by the dash trim panels. Put any screws and clips back into place.Reconnect the car battery. Turn the car on, and if the blown fuse was the problem, the radio should work.
OBD diagnostic tool one stop supplier
Jun 03, 2014 | 2001 Volkswagen Beetle
2007 Jeep Wrangler radio not working at all
yes there is fuse for radio also if this is after market radio on stereo is a fuse on baback by wires there is also fuse box in engine compartment there too is a fuse for radio i belive its a mini fuse check manual for numbered location pull out see if its blow //my jeeep did that too radio fuse was fine but iidecided to look under hood and boom there it was a blown mimi fuse replaced radio all back on
Mar 20, 2014 | Car Audio & Video
RADIO HAS NO POWER
It can be faulty radio amp or radio control fuse is blown out.Check voltage at radio wires.You should get 12 volts.
For more help on car radio problems, I suggest you to go through these troubleshooting links, these will help you: -----
Click the link below: ---
Cigarette lighter, Remote central locking, and Radio stopped working
http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe mode? VW radio CODE?
http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on 1990 Toyota Celica?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram for 1991 Chevy 1500?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
After Market Stereo wiring for 1999 Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
Chevy car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio on 2005 Toyota Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Lexus rx330 Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Lincoln Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash on 2003 Lincoln Aviator
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
Dec 25, 2012 | 1998 Saturn SL
Stereo
It can be wiring issue.The stereo wiring has to be inspected.
Dec 07, 2012 | 2009 Chevrolet Cobalt
2002 saturn lw 300 radio quits
Yes it can be Amp problem,but there are many other possibilities like loose connection,radio wires getting short.
I suggest you to go through the troubleshooting help links related to car radio problems.
Click the link below:-----
Cigarette lighter, Remote central locking, and Radio stopped working http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe mode? VW radio CODE? http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
Nov 23, 2012 | 2006 Saturn Vue
Fuse relay diagram for 84 vw rabbit gti
9_16_2012_11_33_09_pm.jpg i believe this is the diagram you're looking for
Sep 16, 2012 | Cars & Trucks
2002 VW Passat GLX AWD, stereo stopped working
HI,
Passats can be reset if the radio is pulled out and the fuse on the back is removed. Wait for 2 mins, reinsert the fuse and turn the radio on. If this doesn't work, please take it to the dealer for the unlocking of the code, for which he may charge you some fee.
Do let me know if it was helpful.
Regards
Kanu
Sep 09, 2009 | 2002 Volkswagen Passat
After market stereo will not turn on after alternator repair.
to look at the worn out fuse they look like being burned or the aluminum inside the fuse is broken or cut.the fuse for the radio is different to the fuse of the car but still is connected to the battery and check the fuse of the radio it self may be worn out already.
Jul 23, 2009 | Car Audio & Video
Car Audio & Video Logo
87 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
