Question about Ovens
I need a serial number for waves element - Ovens
I have a kennmore oven cant find the serial number for a new oven element its old model looks like mid 1996
The model number/serial number plate for most Sears Ranges is behind the oven door, in one of the four corners of the opening.
Nov 03, 2015 | Ovens
How do I replace a ribbon element in a Viking oven.
Hi, I would like to help you but I need more information. What is the model number and the first 6 numbers including the letter of the serial number please. Also I need to know what ribbon you are referring to as in the location of which component you are referring too wold greatly assist me to assist you. General questions get general answers, because I can't see it I need you to elaborate more information please. Thanks
Nov 27, 2014 | Viking Ovens
My electolux superba convection oven is not maintaining it's temperatures?
Heating elements cold be going bad look at them with a flashlight if either of the elements look thinner than the rest of it then it needs replacing before it goes out completely. With aloud bang a bright arc flash and smoke. Very scary. There's a metal tag on the inside of the oven door jam.write the model and serial number down. Shut off the circuit breaker for the stove should be a 50 amp double breaker. Remove 2 small 1/4 inch screws. Slide the element out straight to you. Remove the 2 wires with the same 1/4 inch nut driver keeping the wires separated .Do Not turn on the circuit breaker till the new elements are installed! !! Use the model and serial number to get your new elements first.
Sep 26, 2014 | Ovens
Tricity double oven
Hi Les. We had a tower oven with three ovens! One oven we constantly used had the element distort, and it had to be replaced.
Most likely the element is on its way out. If you have a multimeter, you can check the voltage supplying the element.
You will need to find the make, model number, and maybe the serial number of the oven to progress.
The details may be inside the oven door or on the rear of the oven. Do a google search, and you should be able to find replacement elements, and a local supplier of original parts or aftermarket replacements.
Jan 29, 2014 | Ovens
Top oven/grill. Element has dislodged from the screw connection. Attempted to screww back the element and there seems no thread for the screws to attach to the oven. What are my options?
Hello Michael Clift - I am happy to assist you. First, I will need your model number (and serial number if you have it) to better address the issue at hand. Thank you.
Jan 16, 2013 | Electrolux EOD6330 Ultrafan Electric...
I need a baking element for the tappen oven model number 486847a. The stove serial number is VF41807648. Can you help
Go to www.ukwhitegoods.co.uk you will need the model number and serial number and place an enquiry. They will get back to you.
hope this is helpful
John
Jun 05, 2011 | Ovens
Have built in oven PBS305PRS00 what would cause broiler element to melt in several different places. It is now is several pieces.
The element needs replacing. That's wat they look like, when they need replacing. Make sure you have the model number and serial number when you Call, or go to repair shop
Mar 30, 2011 | Whirlpool RBS305PDS Electric Single Oven
I need to replace the lower heating element in my older model oven. I think the serial number is 316071601. How do I remove the old element? I am clueless at repair but this should be relatively easy to do...
YES IT IS EASY BUT UNPLUG IT FIRST. REMOVE THE SCREWS FROM THE BACK WALL ABOVE THE ELEMENT AND SLOWLY PULL THE WIRES WITH THE ELEMENT THROUGH THE WALL ABOUT A INCH AND DISCONECT THEM FROM THE ELEMENT
Jan 12, 2010 | Frigidaire Ovens
Needs bottom heating element where can I get the part?
If you are sure the element is out and I am sure you know, be sure to write down the name of unit, model, serial, and if it has one the product number. you can take out the bad element and take it along also to any appliance parts house. Just look in the yellow pages.
BE sure that you turn off the power before removing old element!
Sincerely, shastalaker7
Oct 28, 2009 | Viking VESO176 Stainless Steel Electric...
Ovens Logo
26 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
