Question about Winplus BT1326572 Wireless Vehicle Backup Camera with 35 Color Monitor
Wiring diagram for Winplus wireless backup camera
No image , transmitter light comes on in reverse . definetly power to both units .
Troubleshooting Peak Wireless Backup Camera Monitor ...
https://www.etrailer.com/question-8083.html
Troubleshooting Peak Wireless Backup Camera Monitor LED Blinks but No ... Select Your Vehicle .... the blue light on the monitor blinks continuiously and I have no picture on the monitor? ... If so, it will only come on when the truck is in reverse. ... still blinking and you have no picture, then you need to look at the transmitter.
4UCam Backup Camera Test Cases
www.4ucam.com/backup_camera_tests.html
We do not have all different kinds of RVs, tailers and so on for the actual testing. ... for under 30 feet), the 8907T/8908T comes with a transmitter which is detached from the camera. You can fix the ... Wireless Car Backup Camera Series ... reverse gear, thereverse lights go out and the camera stops sending an image. At the ...
Dec 28, 2015 | Cars & Trucks
Is there a fix or do I replace the monitor? Thanks
You have 3 things to consider. The back up camera itself, The wiring and the monitor. Replacing the monitor may not be the fix. Hard to tell without considering the other areas.
Jun 17, 2014 | Winplus BT1326572 Wireless Vehicle Backup...
Checked connections, all good. Tested with another Winplus monitor, it works . The car battery was changed since then monitor has no picture but power button is on (blue). Menus not working either??????
If another monitor works in place, it sounds like you've found the culprit. If the other monitor works completely normally, and you aren't even seeing menus on that monitor, AND the power button is blue (which normally indicates powered and in use), it sounds like the back light or some internal connection on that monitor is bad. Hope that helps and good luck!
Backup camera will not power up, light comes on but no picture, was working 2yrs....???
As these are aftermarket kits, check the wiring as well all of the connections within it to ensure a good conductive path.
Corrosion and road debris often causes problems like this.
Can someone help me, 2005 Acura MDX backup camera not working
A simple, after-market solution is the truly wireless QuickVu(TM) Wireless Backup Camera. The camera has no (zero) wires. The receiver and monitor are super simple, too! Buy direct from the manufacturer!
Sep 16, 2013 | 2005 Acura MDX
Pioneer backup camara not working
You might want to consider the only truly wireless backup camera system: QuickVu(TM) Wireless Backup Camera. There are no wires to run or electrical connections to splice. No modifications the void the vehicle warranty. Buy direct from the manufacturer!
Aug 16, 2013 | PIONEER PIONEER BACKUP CAMERA NDBC4
Dashdoard wire for backup light
Sorry but we have no wiring diagram here for this car.
Sep 13, 2012 | 2008 Ford F-150
Need sequence to program remote control Winplus model #AC51530(TX2)
WinplusUSA quit making these remotes and receivers for the US, but I stumbled across the Aussie version of the same product and the support for programming them. It worked on my receivers, so here is the link for the .pdf file. Use the RF3672 - Indoor Power Point Controller Kit manual for the winplus receivers. http://www.winplus.com.au/kambrook.html Don't forget to save the file for future use, lol.
Dec 02, 2011 | Cars & Trucks
I need instructions to install my shift3 wireless backup camera with lcd monitor.
You might want to take a look at the QuickVu(TM) wireless backup camera by Trail Ridge Technologies. With no wires on the camera and a simple connection to the cigarette lighter/power outlet, this camera installs in just minutes without any technical expertise. You can find it at http://brilliantivity.com/wireless-backup-camera. Finally, a truly wireless backup camera!
Oct 25, 2009 | Virtual Reality Black Vr3 Wrless Backup...
Wiring installation for back up camera monitor
yes the black is ground, the red goes to a constant power in the fuse block , and the blue goes to the reverse wire to activate the monitor
Feb 25, 2009 | Virtual Reality Black Vr3 Wrless Backup...
Winplus BT1326572 Wireless Vehicle Backup Camera with 35 Color Monitor Logo
95 people viewed this question
Top Winplus Home Security Experts
Lawrence Oravetz
Are you a Winplus Home Security Expert? Answer questions, earn points and help others
