Question about Linksys EtherFast Cable/DSL Router
I have lost cd for D-link adsl2 + Ethernet/usb combo router Dsl-2520u,ver 2.00
  • 826 Answers
You can download from manufacturer website...
Posted on Jan 23, 2013
5 Suggested Answers
ohms
  • 1879 Answers
SOURCE: LinkSYS ADSL2 -AG241Modem + Router Ethernet
Greetings.
Tell me if this is your PHYSICAL SETUP
from the wall jack |-> (phone cable) -in- DSL MODEM -out- (ethernet cable) -in- WAN PORT of Linksys ADSL Router PORT 1 to 4 -out- (ethernet cable) -in- Computer
then :
follow instructions here ( user guide included)
Posted on Jun 19, 2008
master_y0da
  • 26 Answers
SOURCE: lost installation cd
The installation CD is actually just a guide. It does not install any software on the computer. You can configure/reconfigure the router even without the installation CD.
If you need help reconfiguring the router, please let me know.
Please provide also the following info:
1. Who is your Internet Service Prodiver?
2. What is the model/brand of your modem?
Posted on Aug 16, 2008
2Gigs
  • 141 Answers
SOURCE: setting linksys WRT54GX Ver2 with D-Link DSL-2450T ADSL2+router
Your router needs to be configured. Call Linksys Technical Support. If they cannot help you try this http://technicalsupport.blog.friendster.com
Posted on Feb 15, 2009
  • 1738 Answers
SOURCE: The router setup CD won't recognize my ethernet
Make sure your ehternet cable from the computer is plug into the lan port of the router. The setup won't start when the cable is plug into the wan.
Posted on Dec 20, 2009
Testimonial: "Thanks for the suggestion---I'll make sure of this. "
D-link DSL 2730u modem dead after wrong firmware update through wireless
Attempt to do the firmware update, again--connecting always to ethernet for firmware updates. Unfortunately, your modem may be "bricked" (unusable)--in other words, it may be time to recycle it and buy a new one.
The firmware may proved damaged--given that the incorrect firmware successfully installed (hopefully, that was prevented by the device itself--it may have output an error message or code)--or, it was installed incompletely, or the update proved corrupted.
Mar 25, 2014 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a D-Link DSBroadBand G ADSL2+router. I cannot access the internet with the ether cable plugged in. I can access the internet via wireless and the ethernet cable with a laptop. I am able to access...
I suspect that your ethernet adapter has been made 'not enabled', but can't explain how to check it since I don't know which version of windows you're running. If you can get to the Device Driver panel, you can change it there...
May 02, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
My D link ADSL2 plus router work fine thru ethernet cable but has no wireless signal
while connected with a wire surf using internet explorer into the routers console its either at 192.168.0.1 or 192.168.1.1 (most of the time anyway) , Enter the username and pass to get in, often both are admin or admin and blank. check the wireless tab settings in there to see if its enabled and configured.
Aug 27, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I need a dlink dsl 2520u driver
go to www.dlink.com.au. from there on the left hand side click on support. Then click D-Link products specs, downloads, setup guides, troubleshooting & how to's. Now on there are 2 boxes saying SELECT. On the left box select DSL and on the 2nd box select 2520u.Clcik download and from there you can select the driver depending on your OS.
Jan 09, 2010 | D-Link DSL 200 (DSL-200) Modem
Driver
not sure why you will need USB drivers for your adsl2+ modem/ wireless router and 4 port LAN switch. It would help you had provided the model number.
The device uses a LAN ethernet port to connect to the computer. You will need atleast one computer to be on the LAN port for setting it up. Once setup is complete you can use wireless connection for every computer.
The user manual & drivers or the DSL-2740B which appears similar to your product description
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2740B
Not sure if you need these. Your computers will need LAN or wireless drivers to connect to this DLINK modem/ router.
Good luck
Dec 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Need drivers for DSL-G624t wireless router
If you're connecting to the router by ethernet cable or wirelessly, you dont need drivers unless you mean the drivers for the ethernet adapter and/or wireless adpater in your PC.
If this is what you're after, your PC's manufacturer's website is the best place to look if you dont have them on CD/DVD.
If you're connecting to the router by USB port, then the D-Link webiste should have the drivers for downloading.
Sep 13, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
GLB-502T Ethernet Port doesn't work, USB does
check whether the driver for LAN is properly installed...if not install it using your driver cd...it might your solution..check it out
Jul 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Trying ti install my dsl-2640b wireless g adsl2+modem router
If you have plugged the ethernet cable directly into the motherboard, make sure the onboard lan is enabled in the bios, if you have plugged into a pci nic adapter you will have to install a driver for it, winxp should have the driver for your adapter other than that I cannot help any further.
best of luck
Ray Winter
Dec 30, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Adsl2+
don't go for the cd you configure your self abd it think that your dsl not get the perfect dsl link
Jul 10, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Linksys EtherFast Cable/DSL Router Logo
170 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
