Question about Huffy Cars Tri-Wheel Slider
Back wheels of my sons huffy slider have cracked in half, trying to look for replacement wheels. Grace
Need to replace backs wheels they have worn out after only 2weeks and cracked.
5 Suggested Answers
  • 100 Answers
SOURCE: Need replacement balls for a Huffy electronic
I have found the number for Huffy. You should be able to see if they have replacement balls for your electronic basketball game.
U.S. Customer Service
Email: service@huffysports.com
Phone: 1-262-820-3440
Phone: 1-800-558-5234
Fax: 1-262-820-6757
Thank you, hope this helps. Please let me know.
Posted on May 03, 2010
dunnbiker
  • 8546 Answers
SOURCE: can I replace the back
That's up to you and your abilities and available tools...
http://www.parktool.com/blog/repair-help/categories/hub-service
Posted on Apr 07, 2011
dunnbiker
  • 8546 Answers
SOURCE: my son has had his
It is unclear what actually broke here (stem, handlebar itself, steerer tube?) Take it to a bike shop or do some web searching to find a solution that matches what you see. "how to ..."
Posted on Aug 31, 2011
ideaal
  • 1908 Answers
SOURCE: Girls Huffy 16" bike -
If the other side wheelnut is tighten mounted , Use on the other side to adjust a real cone wrench to fixate the pre-set cone without slack and mount the fixating small axle nut (but tight enough) against the pre-set cone. thats the problem because if this is not fixate it will allways become tight running after a few kilometers the rear wheel does not turn smoothly and your bearing can become damaged. rings and extra tight fixate of wheelnuts does not help without a cone wrench this problem cannot be solved. by wheels with coaster brake.
Posted on Mar 09, 2016
How can you remove the back tires?
Need more info please.
Are you trying to remove back tyres off a car?
Jul 30, 2016 | Huffy Green Machine
Replace the spokes on my huffy 18 speed 27 inch bicycle
building and truing wheels is a specialized skill that takes a lot of practice. Most manufacturers use robots to build the wheels to save on labor costs. To have a human build a wheel can cost more than $50 per wheel for the labor. Spokes retail for about $1-$2 a piece and include a brass nipple. Spokes also come in different gauges. Most bike shops that sell spokes usually only carry a few sizes in stainless steel.
If you are only replacing one or two spokes you can take the broken spoke to a bike shop and they can measure it and hopefully have the right size in stock to sell you a replacement. Use the right size spoke wrench for your spokes to unscrew the nipple from the broken spoke, you will then be able to remove (spokes can be very flexible and will bend a lot to get them out of the hub). Observe the adjacent spokes and the lacing pattern to re-install the spoke in the hub and thread it into the new nipple that came with the replacement spoke. Put the wheel back in the frame and use the brake pads as a reference guide to tighten and true the adjacent spoke nipples until the wheel no longer rubs on the brake pads and you are satisfied.
My personal opinion is that on a Huffy, it is faster, cheaper and easier to buy a replacement wheel from your local bike shop for $35-$45. The spokes, rims and hubs used on Huffy's are of very low quality (most don't even use stainless steel spokes) and a new replacement wheel from your local bike shop (LBS) will be ten times better than trying to fix the old original equipment, IMHO.
Nov 18, 2015 | Huffy Cycling
My son has buckled the front wheel of his huffy green machine,we need a replacement as wheel cannot be straightened,any ideas where we can find one.
Have you heard of LOCAL Bicycle Shops? They're everywhere. Use the Search Engine or Yellow Pages of your choice to find one.
Jun 24, 2011 | Cycling
Brake will not stop bike
remove the rear wheel,, and when replacing it again,, turn the brake one turn to tighten the brake itself. to do this you need to hold the opposite side of the axle so it doesn't turn , if this procedure makes it to tight for normal free play, then the "pads" are worn and need to be replaced. they are the half circle looking metal plates that are inside the rear wheel hub,
May 13, 2011 | Huffy Cranbrook 24Inch Cruiser Bike
How do u put the front wheel on the Huffy Cars Lightning McQueen 16 Boys' Bicycle
back off the nuts and washers up on the wheel axel. Place the wheel between the forks positioning the axel in the slots. Replace the washers and nuts and tighten with a wrench
Dec 25, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
Son's can pedal 12" bike
Yes, something isn't turning freely. It's either the front wheel, the back wheel, or the pedals and chain. Lift the bike off the ground and turn the front wheel by hand. If it doesn't turn very freely, it could be the hand-brake is dragging or the hub bearing is too tight. Try the back wheel in both directions. It should move freely in the forward direction. When rolling it backwards it is normal for the pedals to move too if this bike has a coaster brake (that is the kind of brake that is applied by pushing the pedals backwards.) It the back wheel moves forward freely, but backwards is a problem, then try the pedals by hand with the rear wheel off the ground. If this doesn't turn freely, the pedal crank bearing (a.k.a. bottom bracket) is too tight. Once you have identified the problem take it back to where you got it. It should be easy to fix, or they should replace it.
Jul 28, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
My son just bought a 26" Huffy Jolt mountain bike. The rear sprockets spin freely when the pedals are cranked either forward or backward - - that is, there is no coupling to the rear wheel. What can I...
The plastic is to stop the chain from touching the spokes, it cannot cause this problem, either the chain is not on a sprocket correctly or the rear cluster(sprockets) is not working.
Some spray lube may help, but if it is new, take it back to the shop.
Apr 18, 2010 | Huffy Mens Mountain Bike - Crimson Red
The chain wants to jump off while trying to change gears
There are several things that could be wrong:
Shifter out of adjustment
Chain worn
Chain and gear(s) worn
Shifter out of adjustment:
Try adjusting the cable tension by turning the barrel (the part between the cable and the shifter). Count the number of turns and reset it to its original position if this doesn't solve it.
Chain worn:
Chains wear out. hold a ruler up to it, with one end centered on a pin. 12" away, another pin should like up very very very close to the 12" mark. If not, it's probably worn out and needs to be replaced. No way around it. Some say chains are good for 500 miles only. Your mileage may vary. (keep reading...)
Chain worn and gear(s) worn:
If the bike has been ridden witha worn chain for a while, it will make the gears in the back wear faster too, and a new chain alone will not work. If this is the case, you need a new chain and new gears in the back. Often, gears in the back are replaced all at once in a 'cassette'. You'll have to make sure your front gears aren't worn out too!
Nov 15, 2008 | Huffy Cycling
Huffy Cars Tri-Wheel Slider Logo
83 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
