Question about Kirby Heritage II Vacuum
Dust bag central tube broken - how/where can I get a new one or repair it?
The concertina tubing has split.
  • Kirby Master
  • 18,402 Answers
Here is a video how to replace the broken tube and where to get a new one just click on top right of the video
Posted on Jan 22, 2013
4 Suggested Answers
  • 57 Answers
SOURCE: Fix for broken tubing leading into filter bag?
You can replace the black tubing. There is no need to get a new vacuum. You can find the parts you need by following the link below.
http://www.usavacuum.com/Kirby-Generation-3-s/145.htm
Make sure to leave positive feedback.
Thanks USAVACUUM.COM
Posted on Mar 07, 2010
b0sslady2001
  • 357 Answers
SOURCE: Have a Kirby Heritage II
This repair guide should answer all of your questions...
http://reviews.ebay.com/HOW-TO-REPLACE-REPAIR-KIRBY-VACUUM-HERITAGE-CLOTH-BAG?ugid=10000000175632303
Hope it helps! :0)
Posted on May 10, 2012
Have a Kirby Heritage II vacuum. Need to replace a split fill tube. How do I remove the outer cloth bag from the mini-emptor, and then how do I take off the old/attach a new fill tube?
There is no need to remove the outer bag. The fill tube can be removed by cutting it off near the bottom and pulling on the support wire to unwind it from the neck on the mini-emptor. I usually hose down the bag and slosh it around in my laundry sink to clean it. After it dries, the new fill tube can be screwed onto the mini-emptor. You can wet the bottom of the tube with plain water to make it go on more easily. If you screw it on firmly, there is no need for cable ties at the bottom. Re-attach the top adaptor ( bag holder ), and secure it with cable ties.
Apr 16, 2011 | Kirby Heritage II Vacuum
Dust bag was full and have changed it but not getting proper suction since bag change - why?
The extension tube is probably blocked. Check for suction with all the tubes off - if there is suction now then the tubes are blocked - be carefull not to damage them if you poke things in the unblock them.
Feb 13, 2011 | Miele Revolution 600 Bagged Canister...
Mar 05, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Blows out dust
Could be that when you replaced the bag, that it wasn't sealed properly around the intake tube. Try pushing the bag all the way into the neck of the intake tube. If not that, then you may have a broken external intake tube.
Feb 04, 2010 | Vacuums
I just notice when I went to change bag in my Kirby G4 that the whose inside was split open, which made all the dust fill up in the bag. How do I get a replacement part for this and what is that part...
You do not need a whole bag. The bag fill tube is replaceable. can be temp fixed with duct tape and new one installed at home. vacuum inside with another vac and you will be set to replace
Sep 07, 2009 | Kirby G4 Bagged Upright Vacuum
Dust smell when running g4 kirby
The dusty smell coming from my G4 finally drove me to search out the problem. As it turned out, the fill tube had cracked near the top of the mini emptor (the boot) and dust and crumbs were escaping from the tube and into the cloth bag. I tried to repair the split with duct tape and electrical tape, but to no avail. I finally gave up and ordered a new fill tube online for about $8. This took care of the problem, and the machine works like new with no more dusty smell.
May 28, 2009 | Kirby G4 Bagged Upright Vacuum
Sebo Automatic X1 vacuum cleaner doesn't produce much suction.
If the motor really is working, the problem is most likely to be that there's a blockage somewhere, and on this excellent vacuum cleaner there aren't too many places to look. You've probably already looked in the inspection flap on the underside. If not, that's the first place to look. Next is to separate the bag compartment from the base of the machine (press and hold the button at bottom front of bag compartment and just pull the two sections apart - if this hasn't been done for some time, a gentle levering with something like the plastic handle of a dish brush can help). Then look down the rearmost vacuum tube to check that it's clear, also make sure the little sieve on the other tube is clear. That's all for the base section. Now open the bag compartment, remove the bag and check that tube all the way through the hose.
Another possibility is air leakage, and it does happen on older machines that the plastic tube onto which the attachments fit becomes so worn that it no longer seals properly in the hole in the base (where it lives for normal floor vacuuming).  You could also have split in the flexible hose, of course.
If none of this reveals a problem, the motor probably isn't as healthy as you think it is.
I hope this helps. Any questions, just post again and I'll see what more I can do.  I value your feedback, so please rate this response.
May 04, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
HOW DO i CLEAN MAIN TUBE IN HANDLE CLOGED
You'll have to unpick or slide up the rubber rings on the back of the handle at the bottom where the rear of the bag is. Unclip the bag so that it moves freely, slide up the rubber rings and you'll find a series of pop locks. Push these in to take out the main dust spine pipe - also remove the power cord at the top of the handle to release the handle. In the middle of the spine there is one screw that bonds the top handle part to the spine, unscrew this so that you can split the two parts up and check for clogs. Also check the main dust channel that leads to the bag - it is notorious for clogging because of its relatively small dust channel.
Dec 27, 2008 | Oreck XL2200 Bagged Upright Vacuum
Kirby G4 Vacuum "BOOT"?
Greetings from GoVacuum,
The bottom part of the bag, which you referred to as a "Boot" is actually called a Kirby G4 Mini Em-Tor with Fill Tube Assembly. Kirby Part # 199493S. The part is only available to purchase with the fill tube assembly, this is the part that the disposable paper bag connects to inside the cloth outer bag.
Kirby has redesigned this fill tube, as the original design sometimes would cause the inner fill tube to crack. The Mini Em-Tor Fill Tube Assembly, part 199493S comes already assembled with the "boot" at the bottom, and the vacuum bag collar (the part the bag actually attaches to) at the top of it. You will need to remove the cloth outer bag from your old part, and put it onto the new "Boot". The cloth bag connects the "boot" with a special zip tie, which is Kirby Vacuum Bag Clamp. Kirby Part # 196599S. Where it is possible to remove the bag clamp without breaking it, I will warn you that this is no easy task. Spare yourself the aggravation of having to try and remove the clamp, and just cut the bag clamp with a knife or scissors.
You will also have to remove the top of the bag collar at the top of the cloth bag by releasing the fill tube from the inside of the cloth bag.
All of the parts are located on our website, www.govacuum.com. If you have any questions about the repair, you can get me on a live help, chat service located in the top right corner of our website. I'd be happy to walk you through this.
Thanks,
Chris Jones
GoVacuum.com
Sep 30, 2008 | Kirby G4 Bagged Upright Vacuum
Vacuums Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
