Question about Xerox WorkCentre 3550
ERROR LSU HSYNC - Xerox WorkCentre 3550
Samsung ml 2551 Engine hsync error
Dear The problem is with LSU (laser scanning unit) unit. If you are experience open the lsu clean all optical path and test. This may operate .Replace the LSU unit.Thanks.
Oct 13, 2014 | Samsung ML-2551N Laser Printer
E7-03 error code
LSU trouble
After the polygon motor becomes
active, BD signal (HSYNC) from
the LSU is not detected at the
specified times (41 ! 10 times
within 20msec
Jun 19, 2014 | Sharp Office Equipment & Supplies
My printer is showing the error LSU Hsync power error
hello,
your Ml 3051ND printer have bad laser scanner unit(LSU UNIT)you have to replace this unit.best thing is call for service.
or some time laser scanner unit wire harness was damaged. so best solution is call for service.
Feb 07, 2011 | Samsung ML-3051ND Laser Printer
I just replaced the cartridge in my ML-2850. I have an error LSU Hsync Error . Cycle Power
LSU is your laser assy. Sounds like you have a major problem. Laser usually needs replacing with this fault.
Dec 02, 2010 | Samsung Office Equipment & Supplies
There's a colour lazer printer 510 in my office, but when, one day, i come to work, the printer screen displayed, PRINTER LSU ERROR. And what can i do about this? Please guide me. thank for your time and...
First just turn it off for ten minutes and then restart it,
There is a fault in the LSU unit.
1. Use EDC mode to test the HSYNC signal and LSU Motor.
2. Check the Harness connected to the Engine Controller and LSU.
2. Check the Harness connected to the Engine Controller and LSU. --> Refit the harness or replace it if it is damaged.
1. Use EDC mode to test the HSYNC signal and LSU Motor. 2. Check the Harness connected to the Engine Controller and LSU. --> Refit the harness or replace it if it is damaged.. 3. Replace the LSU
If the problem still happens call a repair tech.
Dec 01, 2010 | Office Equipment & Supplies
LSU HSYNC ERROR
mensaje de error hsync en impresora ML-2550
Sep 19, 2010 | Samsung ML-3051ND Laser Printer
Have lsu error also.
Hi ...
LSU stands for Laser Scanner Unit ... you normally get 2 different kind of errors with LSU ...
LSU Hsync or LSU Motor Error ...
If you get this error, it means that the Laser Scanner Unit has gone bad and the only way to get it fixed is to get the printer repaired ...
Cheers ....
Jul 28, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Blank papers comes when the print given
D ear team, Blank papers comes when the print given. Meanwhile it shown the error msg is: LSU Hsync error cycle power pls give me the solution NHPC Ltd.
Feb 03, 2008 | Samsung ML-3051ND Laser Printer
Xerox WorkCentre 3550 Logo
412 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
