Question about Canon Office Equipment & Supplies
Canon ir 2018 system error 007
Copier not able to photocopy. gives error message
  • 10 Answers
SOURCE: copier canon ir 1600
CHANGE THE FIXING UNIT.
Posted on Nov 06, 2007
  • 121 Answers
SOURCE: Canon IR 1600 Error message E000
You'll need to replace the fuser unit. Not exactly the cheapest part of the machine...
Unless, that it, you were taking things apart and happened to unplug something accidentally. If you take the cover off where the paper comes out, look at the connectors directly inside there under the black piece of paper that you'll see. If one of those are pulled out, it could cause the problem.
Otherwise you need to replace the fuser unit.
Erice
Posted on Nov 23, 2007
SOURCE: Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
Posted on Jan 12, 2009
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
  • 7 Answers
SOURCE: how ican geat free canon iR 2018 driver
The driver is available for free at Canon. Click Here to go straight to the page and download the correct driver for your operating system.
Posted on Jul 09, 2009
System error 007 for canon ir 2018
this is error for fixing film rotation. There is no reset code, you need to replace fixing film in fixing unit, Fixing unit is located under left sideway door above drum unit ( green roller ).
Call service!
Aug 26, 2011 | Canon iR 2016i Black and White Copier
My canon photocopy machine 2018 displied system error E007
change the fuser film open the fixing unit and tyr to aply silicon grease on the on the fuser film
Feb 17, 2011 | Canon iR 2022 Printer
My canon IR 2018 copier is giving me system error 007
hi;
its a fixing film problem, your fixing film is not spining properly maybe its paper jammed inside try to clean paper jam carefully else you order new fixing film from canon
good luck
Oct 20, 2010 | Canon iR 2016i Black and White Copier
Error code 007 appears on my canon iR2018
Hello sir; You may go to make a reset procedure as follow; press "additional funtion"(*) key "2" and "8" key in order, then sssw will display, press "OK" key, then select menu item 1 using up/down arrow key, select bit switch 1 using left/right arrow key, then change data from 0 to 1 or from 1 to 0, then press OK, press Stop .
Sep 16, 2009 | Canon Office Equipment & Supplies
E 007
The fusing unit needs to be replaced.
Nov 13, 2008 | Canon iR 2016i Black and White Copier
Troubleshooting, Error Codes for canon ir 2016.
I have problam Canon IR 2016 error message SYSTEM ERROR E 007
Oct 01, 2007 | Canon ImageRunner 2016 Copier
old marine
old marine
