I made 3 partitions on my m 350 but its is only showing 2 partitions
    Problem Solver:
  • 9 Answers
You can go to windows disk management to see more details.
And then you may noted what is the status of the partition which can not be shown out.
I assume that partition may loss drive letter, so it does not appear in windows explorer. And you can use partition freeware to change its drive letter or adjust the partition. source link: http://www.extend-partition.com/free-partition-manager.html
Posted on Jan 24, 2013
I have toshiba a215 and i puted win 7 i hve 2 parttion hdd but it show only 1 partion how i make it show both partions
Windows 7 will only detect the other partition, if Windows 7, is the first operating system, on the first partition, if you have got 7 on the 2nd partition you will not be able to access it.
It is worth also checking "Computer Management" from the start menu, and under "disk management" ensuring the partition is formatted.
Oct 01, 2010 | Toshiba Satellite A215-S4747 Notebook
I have my drive split into 2 partitions but only 1 shows up now, how can i get it back to 2 partitions?
With the drive connected to your computer and powered on, go to the Start Menu and you will see where it says "Computer" or "My Computer" (depending on operating system). Right click on "Computer" or "My Computer" and a menu will appear.
On that menu click on "Manage" and it will open up the Computer Management window.
In the Computer Management window you will see "Disk Management" on the left towards the bottom. Click on that.
In the Disk Management window you will see a list of all of your drives and partitions. Find the hard drive that has the missing partition and see if the missing partition shows up in there. Make sure it shows that the partition is formatted as a filesystem that Windows will recognize such as NTFS and also make sure that it is assigned a drive letter.
If the partition is formatted and does not have a drive letter assigned, Right-Click on the partition and a menu will appear. On that menu, click on "Change Drive Letter and Paths". That will open a dialog box that will take you through the steps of assigning a drive letter to that partition. Once you finish, it should show up in "Computer" or "My Computer" as a drive.
If the partition is not formatted to NTFS or the filesystem you would like it to be (NTFS is recommended for Windows), just Right-Click on the partition and the menu will appear. On that menu click on "Format" and go through the process of formatting the partition to NTFS or your preferred filesystem and it should format the partition and assign a drive letter to the partition and should now show up on your computer.
WARNING: If you format the partition, you will lose any data on that partition and you may not be able to recover the lost data.
I hope this helps! If it does, please leave me a good rating and feedback. I would greatly appreciate it!
Best Regards,
James
Jun 02, 2010 | LaCie (300770) 250 GB Hard Drive
My brand new seagate hard drive is showing on 120 gb space on partition time?
it means your hard disk have 120 gb capacity, you can make partition according to your requirement.
Apr 02, 2010 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
Is it possible to keep the operating system on drive c and the data on drive d and how to do this
yes, partition the drive...
If installing a new OS, Partition drive one with 1/4 of the drives size, then install the os to that partition, once installed if using Windows, partition 1 should show as C: drive, and partition 2 should show as an additional drive.. Each Partition will show as a separate drive..
If the OS is already installed, you can use a program such as partition magic, or you can use MS disc manage (right click My Computer, Select Manage)..
Oct 03, 2009 | Computers & Internet
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
Partition problem
In my humble opinion, the best option is to install a second (blank or larger) drive. Install some recovery software such as "easy recovery pro" or something that will be able to read files from a filesystem that has had the partition table written over. Start with trying to scan using FAT32, and in failing that, try NTFS. Restore the data to the second drive, format the first and partition as required. Copy the data back to the first drive to the partitions that you specified, and erase the data from the second drive. A free option may be pandora recovery, available at http://www.pandorarecovery.com/features/
Jan 20, 2009 | Microsoft Windows XP Professional
Partition Problem
Yuou must backup the data of d:\ in another harddrive or volume before doing this backup your data in another volume and then merge the data you can even copy the sectors from partion magic .Data can be recovered by using data recovery softwares.
Partition parameter
From the data you provided, the D drive is deleted and is newly created. But it is not yet formatted. So the data is virtually deleted. Why I said virtually is because, the data is still there on the drive physically and you can recover it using third party tools like OO disk recovery tool. That is why partition magic is still showing data on it.
And it is also obvious that the task which Partition Magic started (splitting drives) is not finished properly. That is why K partition is incorrectly formatted. It is natural that it asks format of D drive because D drive belongs to no file type and it must be of FAT32 or NTFS or other file system.
The solution for your problem is try recovering your data on D drive using disk recovery tools. Then format it using FAT32 or NTFS. Format K drive also in FAT32 or NTFS. Use either partition magic or Computer Management. Since already PM caused problems on your computer, try computer management. It is safe.
What steps to take after installing a hard drive on a toshiba 350
After replace new hdd, u need to performs following:
Update of HDD program data and UI data.
1) Create partitions. (In case of using the download jig, this is not necessary.)
While pressing [3] and [CLEAR] button, turn the power ON.
When "Firmware Version Up Mode" appears on the LCD, key in [3] and press the [START]
button.
2) Format the HDD. (Setting Mode (08-690: 2))
3) Update with the download jig or USB storage.
4) Format the HDD. (Setting Mode (08-690: 2))
* When the FAX unit (GD-1150) is installed.
Start up with the FAX Clearing Mode (1*)
Perform the 1*-100 (FAX Set Up), 1*-102 (Clearing the image data) of the FAX Clearing Mode.
Nov 26, 2008 | Toshiba e-Studio 350 Copier
175gb missing from 250GB hard drive
Appreciate the "Ask Me".
The only plausible explanation for the missing disk space would be the protected folder "System Volume Info".
Re-formatting would not restore your free space, however, re-partitioning would. May I suggest that you try PowerQuest Partition Magic. Of course like formatting, re-partitioning would completely delete the partition itself and would grant you back the entire disk space.
Unfortunately you can not use the same with the 1st partition since that is your active partition and presumably where your OS is residing. A workaround is to use another hard disk temporarily and transfer all the contents of partition 1 and make that eventually as your primary HD. Thereafter, re-partition again the entire 250Gb HD.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 27, 2008 | LaCie (300770) 250 GB Hard Drive
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
