what is the brand of your cellphone sir? please specify the brand and model of the phone sir... u can identify the MCU, PPM, and CNT by its file size... MCU has the biggest file size compared to the PPM and CNT... followed by PPM which is second largest size and then CNT which has the smallest file size.... you can see it by clicking the VIEWS icon and then DETAILS.. goodluck.
hi,
are you bored with your white screen or yellow backlight cellphone?that
sometimes you cant see the text messages in your screen ... i want to share how to convert non-colored phone like 1110i ,1112 ,1200 into colored phone...
you need this tool and gadget in converting 1110i to 2310
procedure.. a)open jaf interface b)connect the phone to jaf box c.)select dct4 d.)thick check e) if the phone is connected put MCU ,PPM,CNT of 2310 f.)flash the phone g.)write 2310 pm h.)after flashing ,the phone is in contact service status ,dont worry i)just unlock the phone.. j.)replace the LCD (glass display) and now you have 2310 colored phone..
in converting 1200 to 1208 colored phone just follow the procedure above and replace the PM files,flash files and LCD to 1208...
you can get colored LCD or glass display in the defective phone like 1600 ,they are compatible..
if you have no gadget that i have mentioned above ,dont try this..i hope it will help you..thanks
1) Check your version on your phone by pressing *#0000# You will see your current softwareversion (currently probably 10.something and that's why you are on this page). The model probably is N97 and the type RM-507.
It is also important you have already installed the PC suite.
2) download the new firmware via Navifirm
Run it (start-up takes a while, it retrieves data from the internet) and select the version that you want to download. Make sure that you know which firmware you want to download. A list of all the product codes (and the ones which are already updated can be obtained here)
3) Store the files that you have downloaded in following folder: C:\Program Files\Nokia\Phoenix\Products\RM-507
where RM-507 is equal to the code that you retrieved in step 1
You now have possession of the part that you need to upload to your phone!
To be able to flash this on your phone you need toinstall and get J(ust) A(nother) F(lasher) working
Download JAF version 1.92.62 here, and in order to get it working download OMG JAF PKEY Emulator v5: here
version 1.92.62 does not know the N97, so 1.92.64 can be downloaded. You don't need the .exe file just the .ini files. So download JAF version 1.92.64 here and only put the .ini files in the directory where you installed version 1.92.62
When this is done, open OMG *** PKEY Emulator v5. After pressing go without changing any setting you should get JAF running.
You first get an error message that Box drivers are not installed. This is OK as you don't have a box. If you get a query regarding installing new drivers keep the ones you currently have (those you got when installing the OVI suite and they are perfect)
Press BB5, now we need to tell the programm where to get the new flash files.
First select: dead USB (even if your phone is still working) Manual flash , factory set and normal mode.
If your phone is still working you can press .ini when it's connected. It will automatically know where your You can do this by connecting your phone and press: use ini, or when it's dead press the buttons MCU , PPM,CNT and APE one by one.
You should point them to your directory
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-507\RM-507_11.2.021_prd.core.C00 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-507\RM-507_11.2.021_prd.rofs2.V28 (SWAP the file from RM-505_11.0.021_prd.rofs2.V26 and rename it to RM-507_11.2.021_prd.rofs2.V28) CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-507\RM-507_11.2.021_C01_prd.rofs3.fpsx APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-507\RM505_507_11.0.021_uda9_001.uda.fpsx
Also make sure you click the option: Change also product code and uncheck CRT 308. Now make sure your phone is switched off and battery is in! Now take out the part that goes into your phone untill the program tells you to switch on your phone after you pressed FLASH.
flash firmware file same mcu &ppm &after that flash patch file with cnt button if doesnt successfull just unlock by jaf if still having same condition clean circuit board with petroll try it
hi, your phone is having corrupted software,you have two option to fix that..first if you have this gadget you can do it it on your own... 1.) activated mx key dongle with ufs interface 2.)ufc cable 3.)5800 flash file ,MCU ,PPM ,CNT
here is the procedure, A.) open mx key B)connect the phone to mx key using ufc cable C.)bus scan D.)if the phone is now connected and you read the info E.)put mcu ,ppm and cnt (warning ,the flash file must be higher than former version because 5800 is undowgradedable,to prevent more damage on its software... F.)back up rpl and pm before fllashing (in mx key thick SERVICE <IMEI AND SECURITY ,ALL SECTION G.)the phone is now safety for flashing ,then wait until its done...
if you have no gadget and tools that i mentioned above ,go to a nearest nokia care in your place ..i hope it will help you ,thanks for trusting fixya
hi, first of you need this gadget MX KEY DOGLE and ufs twister box as your interface ,ufc cable2 to connect it in your computer...flash file which contains MCU ,PPM and CNT...its very technical but i hope you will understand it because you did not ask this question if you have no knowledge in mobile repair...
here is the step , 1.open mx key 2.select ufs as interface 3.connect phone to ufc cable ,set to 7.5k 4.thick dct4 (because 6255 is dct4 phone) 5.bus check (because the phone is dead) 6..set your MCU ,PPM ,CNT 7.flash the phone and wait until its done... in case you have no gadget as stated below,go to nokia care center to fix your phone..i hope it will help .thanks
you should reflash your phone. try to download nokia firmware on www(dot)blue-nokia(dot)com
and to flash your phone with usb you need to download BB5 reaper software or you can use J.A.F emulator (c r a c k of J.A.F) first you need to download the software of JAF, Instal it, and run the emulator
the program opened.chose BB5 tab and tick the USB connection. before you flash your phone, instal your phone firmware ( don't downgrade version ). insert the MCU PPM and CNT on each tab. MCU is the micro controler PPM is the data contain the language (choose the PPM code that contain your language) CNT is content data (choose the CNT code same with the ppm)
or you can select the correct product code, it will automaticly set the MCU PPM and CNT
with multi box
Attach phone
Lock
press yes to download RM-305************x.unlock_img
now flash your phone with downloaded file (mcu part) with jaf or ufs
return to multi box software ..
Attach phone
Lock
now reflash your phone with original mcu-ppm with jaf or ufs
your phone is ok
Dear.
if u have a any sara soft box and ur phone is not power on first u have to check the phone from button after connectiong to cable. if check status is ok then first of all take mcu file the identification is that in most of the mcu file at the end there is "0" and its size in kb is the larger than other files. after if u have to take ppm file its is the language pack u want to install in ur phone. mostly at the end any single alphabatic such as a,b,c,d,.......... then take cnt file if that mobile have cnt option. then press the flash button flashing will be started when flashing complete then unlock ur phone by using "initial sim l ock" option. if during the flash the flashing is aborted then reconnect u mobile and flashing agian if same prob it may be the harware check for h arware.
