Question about Garden
Riding my ttr 250 Runs fine then just dies when ded no headlight starter or anything. I wait 10 mins kick it and starts rides about 2 Mins and dies again what could it be?
    New Friend:
  • 8 Answers
Maybe trash in your carb. Take the carb off and clean every hole you can find. Put it back together and reinstall. Should work fine.
Posted on Jan 22, 2013
jgwhomeequip
  • 1902 Answers
SOURCE: Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
Posted on May 22, 2009
bridgesdean7
  • 41 Answers
SOURCE: 15.5 horse craftsman riding mower. Runs fine
carb is probaly dirty
Posted on Jun 03, 2009
  • 13 Answers
SOURCE: mower shuts off after running for 20 mins. then
Sounds like you have something intermittent and its going to be hard to isolate. After it shuts off will the motor still turn if so see if its getting fire.
Posted on Sep 29, 2009
  • 229 Answers
SOURCE: engine starts and runs,mows for 30 min then chokes
i had the same problem i talked to a repair shop and they said the coil was going bad and when it heats up there is a short in it (follow the spark plug wire back to the motor and the coil is there ) i replaced the coil pack and problem solved, hope this helps.
Posted on May 16, 2010
vetteman3002
  • 2299 Answers
SOURCE: On my Craftsman Riding Lawn
The problem is more than likely the coil. The coil is nothing more than a coil of copper wire. When the coil gets hot the wire expands causing the coil to open or lose connection. When it loses connection then the spark plug quits firing.
PLEASE RATE! Click on the 4 thumbs ups!
Thanks! Have a GREAT DAY!
Posted on Oct 19, 2010
2003 v70 new fuel pump starts runs 10 mins. dies won't start again for a few hours
sounds like a fuel filter issue is there an inline filter
Mar 19, 2017 | Cars & Trucks
My new battery died after 35 mins of riding
sounds like alternater problem
Sep 08, 2014 | Motorcycles
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
04 Gsxr600 jerking and engine dies after riding for awhile.
I have an 05 with the same problem. Sounds like your STVA went out. Do you still have your butterflies wired open? I know how to repair the stva fixed mine, and saved hundreds....if your still on this post email me so we can get our bikes fixed. also check your kick stand sensor! This can malfunction and cause same stalling problems.
Apr 22, 2012 | 2004 Suzuki GSX-R 600
LT1550: runs for about 30 mins on 1/2 to 3/4 throttle. sputters and DIES!!!!! I have to wait a day or two before it would start again.
Try this:
When it begins to stall, loosen the gas cap. If the engine smooths out, clean the vent holes on the cap.
Gary
May 08, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
My Honda hornet starts fine but after Riding it for say 5 mins then it will die. Then it will start after 10 mins and run fine for another 5 an repeat. :(
theres a few things you can check
1. check the fuel filter
2. check the fuel lines ( no blockages )
3. clean the carb
Mar 26, 2011 | Honda Hornet 250 Motorcycles
88 Toyota Corolla backfires through carburetor.
If that is carbureted, and has a mechanical fuel pump, try running a length of fuel line from inlet side of pump to a gas can that has fresh, clean fuel, and if it runs good that way, you know problem is most likely in the tank. Removing the tank & cleaning it out is best solution from there. I'd even be tempted to add a small bottle or 2 of Lucas Fuel Sytem Cleaner to first fill in clean tank, just to help clean lines as well as carb.
May 20, 2009 | 1994 Toyota Corolla
Mower runs for 10-15 mins. ands shuts off
I had the same problem on my craftsman 18.5 hp, the problem was in the choke, the spring was broken, and the choke was not free, replaced the spring and it is fine now. Check it out. Good luck.
Feb 26, 2009 | John Deere Garden
Open Questions:
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
