Question about HP iPAQ H4155 Pocket PC
HP IPAQ 2003 internet problem
I am able to connect to a Wireless Network but I can't seem to get in the internet. The error message says that "The page you are looking for cannot be found." I have tried inputing other websites and it still says the same thing. Please help me. Thanks in advance.
  • Anonymous Nov 18, 2007
    Cannot connect to my lynky's wireless internet with my iPAC?
  • Anonymous Jan 02, 2008
  • 608 Answers
This problem seems to be with the wireless network itself. Perhaps it's not connected to the Internet even though you are connected to the lan. Make sure your default gateway setting is the same as that of the lan. If there is lan administrator, obatin the settings you should have from that person.
Posted on Mar 17, 2010
SOURCE:
My ipaq 211 is connecting to the internet but im getting a 'page cannot be found' message when browsing
THAT IS CONNECTION PROBLEM OR WHEN DHCP IS DISABLED ONYOUR WIFI OR WIRELESS NETWORK
Jul 31, 2013 | HP iPAQ 211
I have hp pocket pc,but problem is that i can not connect with internet.plssss replay me how to connect with internet
What model is your ipaq? Does it has WIFI? If it does then:
Make sure that your WLAN is ON
Go to:
Start, IPAQ Wireless, and turn ON WLAN then:
Go to:
1) Start,Settings, connections tab, connections again, Advance tab, Network Card and you should see your Wireless networks.
From there it will vary depending if your wireless device has security on. WEP, etc.
Hope this helps.
Aug 16, 2010 | Microsoft Windows Mobile 2003 for Pocket...
On a new iPAQ 111, I can't connect to a network wirelessly
Have you tried resetting your iPAQ? You do that by pushing the little button on the side with the stylus. The screen will go blank for a bit, and then windows will restart. I had bought mine used, and when I got it, I had the same problem in that I never got the screen that let me select the wireless network. It fixed mine. Once it is working again, try selecting "View WLAN Networks" again, and you will see a list of networks that it can hear. If the SSID Brodcast is enabled on your wireless access point, you will see your network there. If SSID is not enabled on your WAP, you will need to type in the name of your network before it will find it.
Hope this helps. Sorry it was so late in being posted.
Jun 30, 2010 | HP iPAQ 111 Classic Pocket PC
HP iPAQ H4150 Pocket PC
Go to Settings-Connections-Connections-advanced-Network Card.
You will see all available wireless networks in your area. Double click the desired wireless network and tap connect. Note whether the desired network has been connected.
Hope this help,
Harit
Jun 26, 2008 | HP iPAQ H4150 Pocket PC
IPAQ wireless connectivity
always start with the simplest answer first so make sure you have WiFi turned on. Think back, have you changed the wireless security on your router? If so you may need to re-enter the network details or add your iPAQ's MAC address to the access control list on the router. In the bottom right-hand corner of the home screen you should have a small HP Wireless symbol, if you tap it you should get your HP Wireless control panel on screen and can 1: turn WiFi on and off, 2: manually enter the WiFi network details and 3: search for WiFi networks in range.
Aug 16, 2007 | HP iPAQ H5555 Pocket PC
Connecting a Ipaq RX3715 to a wireless router
First, you have to be sure your ipaq has wi-fi feature is on and you can check on network connectivity option for any wrong setup there. According to your information, your ipaq is not recognized by your router and I agreed that your router is working normally. Try to reboot your ipaq and be sure to get wi-fi to turn on and try to connect it again. I have my Dell Axim also used Windows Mobile like Ipaq and it connected easily with no issue. The message in your to show me that you need first to identify your ipaq before you you can get it to connect to your network. I hope this help.
Mar 05, 2007 | HP iPAQ RX3715 Pocket PC
Wireless Internet on iPAQ 2215
You will be wanting an SDIO wireless 802.11b card.
Sep 15, 2005 | HP FA162A for iPAQ 2215/4155 Keyboard
Ipaq 4705 wont connect to internet
Try running through this WI-FI setup tutorial, its very helpful. http://wifi.aximsite.com/
Sep 08, 2005 | HP iPAQ HX4705 Pocket PC
HP iPAQ hx4700 Pocket PC
if your PCs connect wireleslly, then I assume you have set up a home network with a router/modem. Sometimes the modem comes combined with a router. If this is the case, then the 4700 has all you need to connect it to this network and access your emails and internet. This is an example of my setup with my 4700... Go to Start > Settings > Connections > Connections > click on Advanced tab at the bottom click on "Select Networks" button Both entries on this page should be set to "My Work Network". Click "OK" > "OK" back to Settings screen. Go back to Today Screen. Now click on the iPaq Wireless icon at bottom right of this screen. If the WiFi button has an 'x' on it then click it to turn it on. A blue light should now come on at the top of your ipaq to indicate that wifi is on. Click on the 'Settings' button You should be able to see your network on this screen - "Configure Wireless Networks" Networks to access should be set to "All Available" Check the box to 'Automatically connect to non-preferred networks' If the Network is available but not connected, then click on it's name. On this next screen you should select next to 'Connects to' - "The Internet" Then click OK If the Network shows 'Available' and not 'Connected' then click and hold on the name of the network and then you can choose 'Connect' Then under 'Network Adapters', on that screen it should say ... My Network card connects to 'Work"
Sep 07, 2005 | HP iPAQ HX4700 Pocket PC
Open Questions:
See all HP iPAQ H4155 Pocket PC Questions
HP iPAQ H4155 Pocket PC Logo
106 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
