2 or 3 times in the last few weeks we will be driving my husbands 2002 Chevy Z71 1500 pickup and the battery light will flash and all the accessories will quit working. We replaced the battery after this first happened, however now it keeps happening, however not all the time. Help! Please, can't afford to keep paying for labor when nothing is getting fixed.
Hello;
It sounds as if the main power lead could be loose powering the dash. There are several main power blocks, make sure your connections are clean and tight. I have seen the circuit board for the dash fail but not often. Hope this helps.
Thanks;
Rich
RPM Northwest
Hello;
Thanks;
Rich
RPM Northwest
Hello;
Your husband can check the connections, you will see if they are loose. The circuit board may not show on the tech's computer as failing. If you see anything loose or corroded, clean and tighten. Hope this helps.
Thanks;
Rich
RPM Northwest
Thank You! Is this something that My husband could find in the manual how to check, or should we have our local shop checkit out? Also if the circuit board is bad in the dash, will it show on their testing machines, or not?
