Question about Hansgrohe Raindance 240 AIR Showerhead 27474821
Air rain shower head leaking - Hansgrohe Raindance 240 AIR Showerhead 27474821
    Scholar:
  • 72 Answers
The most common issue with this type of head is water deposits building up in the spray face. This will cause the unit to express water from the venturi in the center of the spray face as well as other places. If this is the case the best solution is to remove the unit and soak it in CLR for about ten minutes. Then rinse it well and reconnect to the water source. Run water throught the shower head and while running rub the rubber water channels to further break up and clear out the deposits. Then repeat the process at least two more times or until the deposits are cleared out. If you need further help feel free to contact Hansgrohe Technical at 1-800-334-0455.
Posted on Jan 22, 2013
Rain water leaking from under the bulk head drivers side
Hi Ajgannon,Take out the plastic cover where the wipers come through and clean out the rain water drain pipes. (on either side of the body, at the lowest point under the covers) that should clear the problem and stop you from taking a shower in the car.Regards Johngee10
Jul 23, 2011 | 2003 Volkswagen Passat
Does the opella 10" rainshower
Non of the rain heads have high pressures as the name implies it is like a gentle rain.
FYI I love mine
Mar 13, 2011 | Opella 10" Shower Head - Wet & Warm -...
My rain shower is blocked , only 20% of the holes are working, what do I do, It is two years old and slowly the holes are not working
Your shower head is getting clogged with calicum or lime and will continue to plug up worse until you clean it.
Remove the Shower head from the Shower pipe and submerse it in a bucket mixed with 50% Water and 50% CLR. Let it say submersed for about an hour, then rinse it completly under fresh running water to wash away the CLR and the dissolved calicum/lime.
CLR can be bought at numerous places such as Lowes,Home Depot, and numerous other places.
Please rate me
Jan 15, 2011 | Grohe 27130000 Chrome Rainshower Rustic...
My husband and I had a new house built and the plumber installed a rain shower head above the shower and a normal shower head. There is only one valve to turn the shower on and when i do water comes from...
There is a shut off valve that will screw onto the shower head extension pipe. It would fit on the pipe and then the shower head will screw back onto it.
Lowes or Home Depot should have them. Here is link to show you what to look for.
http://www.amazon.com/Danco-89171-Shut-Off-Shower-Chrome/dp/B000JFNPJE
I hope this helps.
Jun 22, 2010 | Plumbing
Water leaks shere showerhead joins the shower stem
when reconnecting the shower head to the pipe coming from the wall..
did you use some pipe tape, pro dope or another type of joining compound?
this seems likely to be the problem.. if you don't have any on hand, visit a hardware store and ask their staff for pipe tape for plumbing and you should be pointed into the right direction.
May 12, 2010 | Water Pik & Wallmount Showerhead
How to install
Take a cloth or rag and a large pliers... place it around the nut of the old shower head and turn it to the left or counter clockwise as you are looking up at the shower head...
Then take the new shower head and spin it on there clockwise till it is snug...that's all there is too changing it...
heatman101
Apr 22, 2010 | Pioneer 2 Handle Satin Nickel 6" Rain Head...
Shower - Rain head won't turn off so hand held can be used solo.
Probably the fitting is not working properly. Please change the fitting.
Apr 17, 2010 | Plumbing
My Hans Grohe rain shower head is having a lighter spray recently. Is there a way to improve the spray force and/or clean it? Thanks, Therese Terschuren
Rain head showers are a nice thought, but they come with a bundle of problems. This is common one, though, so fear not.
As long as your regular shower head isn't losing pressure (I'm assuming that you have at least two heads instead of just one rain head) I would recommend carefully removing the head with an adjustable wrench and letting it soak in CLR (calcium lime rust) for at least an hour. Often times minerals in water will build up in the small holes on a shower head and greatly reduce efficiency.
Remember to apply teflon tape to the threads before carefully retightening the shower head to avoid spraying water from the wrong end!
Mar 25, 2009 | Home
The weight of the arm and rain head is too heavy for fixing
can you at all shorten the length of the arm to make the head lighter or can you do the adjustment near the tiles up tighter apart from this attach unsightly bracket from the head back to the wall at worst mate start pulling tiles off ouch ! wish i could more help glenn..
Nov 20, 2008 | Grohe 27.217.EN0 Rainshower 6" Ceiling...
Hansgrohe Raindance 240 AIR Showerhead  27474821 Logo
2,607 people viewed this question
Top Hansgrohe Home Experts
Daryl Gleaton
Dan Apthorp
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
