Question about Freestyle Adrenaline Sport watch #12442 Watch for Women
ALARM SETTING ON ADRENALINE LIGHT DIGITAL WATCH
NEED TO DEACTIVATE THE ALARMS
  • Freestyle Master
  • 18,394 Answers
How do I set the time on adrenaline digital watch?
two standard digi watch setting processes
1 press and hold mode button until time start to flash
then use the start button to move between hour , minute sec etc and the reset to adjust the time, when correct time set press hold once more to return to normal time.
2 press hold button one push at a time on the third push the time should start flashing , follow the above processes.
Mar 04, 2015 | Freestyle Adrenaline watch
How do you shut off alarm on g500a watch
Use the mode button to switch to the alarms. Use the Receive button to scroll through the alarms until you get the one that you want to turn off. Press the Time Memo button to toggle it on or off (you'll know it's on when the pie piece in the 3 o'clock part of the right-most circle is lit and it's off when that pie piece is unlit.) Use the same method to turn an alarm on by toggling the alarm to the other setting.
Feb 19, 2011 | Casio G-Shock GW500A-1V Wrist Watch
How do you set a timex ironman wathc and how do you use the stop watch and alarms
Hi hdirkse,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
Sep 25, 2010 | Timex Ironman 53151 Wrist Watch
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
How to set alarm clock
Press the lower button on the left side of the watch to enter the menu. Then press the alarm selection key (5). Use the 1 and AB keys to scroll through the existing alarms. Once on the desired alarm, press and hold the upper button on the left side until the left number on the hour starts to blink. Use the number pad to select the desired alarm time. You can scroll past unneeded number spots by pressing the lower button on the left side. When finished, press the upper left button again and you are good to go. A quick press of the upper left button will activate or deactivate the alarm. Make sure the black lines near the upper left button are visible to indicate the alarm will go off.
Dec 11, 2009 | Casio E-Databank EDB6101C Wrist Watch
Can't set time on aqualite watch-field ranger
I have an aqualite field ranger watch too. I lost the information but I found another notice for another watch and I was able to set the TIME as well as the alarm. I am not despairing as to one day set the date correctly! ;-)
The instructions I found are for "LIFELONG Chrono Alarm Sport watch" from Hanig & Company. The watch this particular instructions comes from has a rectangle LCD display that only takes the center of the dial, and only 3 buttons for the functions.
Aqualite has 4 buttons, but one of them is only for lighting the dial only, therefore if we use the 3 other buttons the same way they are described in this manual, it will work.
Aqualite has 4 buttons:
1) top right (we will call it S1 like this manual does)
2) bottom right (this will be S2)
3) bottom left (this will be S3)
As I said the number 4) (top left) is only for light and we will forget it since it is not needed to set our watch.
Setting the minutes, hour, date month and day:
Press S3 3 times, or until the following are flashing in the display : TU and seconds
Set the minute: press S2 once and advance by pressing S1
Set the hour: press S2 and advance by pressing S1
Choose from AM (A), PM (P) or military time (H)
Set the date: Press S2 and advance by pressing S1
Set the month: Press S2 and advance by pressing S1
Set the day Press S2 and advance by pressing S1
Press S3 to bring you to the time display
Setting the chronograph:
The chronograph feature will store and add to the last recorded time interval up to 23 hours, 59 minutes and 59 seconds in the time display.
1. Press S3 (flashing in the display: SU, FR, SA)
2. Press S1 to begin. Press S1 to stop.
3. press S3 to return to the time display.
Setting the lap time:
The lap feature will record from 1/100th of a second up to 23 hours, 59 minutes and 59 seconds.
In the time display.
1. Press S3 (flashing in the display: SU, FR. SA)
2. Press S2 to clear setting
3. Press S1 to begin. Press S2 to stop.
4. Press S1 once and S2 twice to reset.
5. Press S3 to return to the time display.
Setting the alarm and snooze:
The time alarm features with a convenient snooze function which will sound 5 minutes after the first alarm in the time display.
1. Press S3 twice for the alarm mode (hour will be flashing): advance by pressing S1
2. Press S2 once (minute will be flashing)
3. Press S3 to set alarm and return to time display
3. Press S1 to deactivate alarm
5. After 5 minutes, snooze alarm will ring. Pres S2 to deactivate.
6. Press S1 and S2 at the same time to deactivate the alarm at any time.
To test alarm
In the time display
1. press S1 and S2 simultaneously for alarm test.
Hourly chime
Your chrono alarm sport watch ha the option of an hourly chime in the time display.
1 Press S2 and then press S3 to activate hourly chime
2. Repeat process to deactivate
Jul 23, 2009 | Watches
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Mar 03, 2009 | Bulova Watch
Turning alarm offI
how do I turn off the hourly setting
Jan 19, 2009 | Casio DB360G-9A 30 Pages Telememo Watch
Alarm goes off at midnight & repeats for half hour, and not set
what you have to do is
1. press the mode button until you get to the setting that has "AL" at the bottom right.
2. then you press the "receive" button to switch between the four alarms.
3. as you are going through each alarm time, you need to look in the circle at the top right. When you are going through the alarm times, if there is a mark next to "ALM", you need to press the "time memo" button so that the mark next to "ALM" is no longer there.
4. repeat step fout for all of the alarms, and the problem should be fixed.
Apr 13, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Unwanted alarm
using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
Jan 08, 2008 | Oregon Scientific SE233 Wrist Watch
Freestyle Adrenaline Sport watch #12442 Watch for Women Logo
186 people viewed this question
Top Freestyle Watches Experts
ray gallant
Are you a Freestyle Watch Expert? Answer questions, earn points and help others
