Question about Bosch Dryers
Bosch maxx 7 lost instructions
Just managed to lose instructions, need to know how to clean/change filter and how to empty water?
IFIXALL
  • 868 Answers
SOURCE: Bosch Maxx 6 doesn't dry anymore?
Yes,it is the first thing to check ,If you can somehow see if its glowing when you start the dryer.It may also be a thermal fuse.
Posted on May 23, 2008
SOURCE: bosch maxx wtl 6300 dryer when
Hi Guys...
At least I can shed some light on how to open the bottom part.
When you are looking into the dryer with the door open, take a look at the bottom hinge of the door. There is what looks like to be button popped out slightly..
Place your thumb on it and press. This should open the bottom part of the dryer.  Then clear out the gap between where the lint filter connects to the other units below it (when the door is closed...)
Hope this makes sense... there seems to be a sensor there..  I just cleaned mine so praying that the beeps stop.. Its been driving us mad for the last 8 months!
Posted on Oct 25, 2008
svicari124
  • 18 Answers
SOURCE: I have a Bosch Maxx condenser tumble dryer that wont work.
Have you taken the condenser itself out from the bottom of the machine? Remove the condenser from the bottom door and rotate the clamp tags which secure it in. Slide condenser out (aluminium mutli-finned box assembly) and carefully take it outside. Use a garden hose with lots of water pressure to spray each vent passage carefully to clear lint and dust away. Passages must be cleared in both directions, long ways and cross ways. Cross ways is the problem area and once you finish clearing the air ways you should see daylight through the condenser easily. Reassemble and always clear lint filter in the door /drum area.
Good luck.
Sam
Posted on Sep 20, 2009
SOURCE: Bosch maxx 7 sensitive dryer wich stops everytime
Technician just solved that annoying problem. My dryer is few months old and without pump, so condensed water is dripping to tank by gravity. During drying cloth is collected on filter and condenser, but some amount of cloth goes into pipes and canals on the bottom of dryer and clogged non-return valve where tank is inserted. Side panel ha has to be removed, canals and valve cleaned. To prevent problem technician suggested condenser and filter cleaning after every use. Valve can be removed from bottom without removing side panel.
Posted on Feb 22, 2011
SOURCE: I have a two year
I had exactly the same problem and got it fixed by the Bosch repair service today.
The culprit is that in certain areas there may be algae in the air that thrive to grow in the main water reservoir and clog up the water pump that fills the condensation compartment.
(note: There are two water tanks in the Ecologixx 7 - one user serviceable condenser tank up top and the non-user serviceable main water reservoir sealed inside the machine)
This is main water reservoir is located sealed under the water pump under the tumble dryer drum.
Dismantling instructions: 1. remove the top of the tumble dryer first (two screws at the back 2. remove the right side panel with another few screws (looking from the front) 3. disengage the multi-tooth elastic band by twisting the spring loaded roller at the bottom).
After this you have access to the water pump and the Styrofoam float that triggers the empty condenser tank warning.
If the pump is entirely clogged you might need to replace it and the float.
Then clean the bottom water reservoir from the algae infested water with a pump+hose and a bottle washing brush and circulate clean water through the machine (re-engage the elastic band before running the engine) with the Warm-program.
To kill the algae you need to run about 250ml of clear raw vinegar through the pump system by running the machine in the Warm program for 10min and then rinse the excess vinegar out by putting about half a condenser tank of warm water into the machine and running the Warm-programme for 30min. (this will release the clean water into the condenser unit for the self-cleaning function and then pump it back up into the condenser water tank and dilute and circulate the raw vinegar out of the machine).
You should also do a vinegar sanitization run before all extended periods of disuse of the machine by pouring 250ml of vinegar into the large round hole under the top condenser tank (this is where the condensed water is poured for the self-cleaning run).
Run the Warm-program without the condenser tank in place until you can verify visually that the pump is circulating the vinegar through the hose in the top left back corner of the condenser tank opening (there is a overflow drain at the back so everything coming up goes promptly back down into the main reservoir (small hole in the back corner bottom).
Then place the condenser water tank half full with hot water (not boiling) and let the Warm-programme run for 30min to dilute and circulate the vinegar-water solution out of the machine back into the condenser reservoir.
Posted on May 30, 2011
My bosch maxx 7 sensitive dryer is not working - no lights are lit up, door is closed, filter is clean, container is empty, just beeps twice when i pusch start
Well I would recheck the water reservoir is fully inserted ....the door has no debris inside the lock....the bottom filter is cleaned not just the door filter.if this still not fixes then try a reset by switching off at socket then whilst holding start button without releasing for at least five seconds turn on power and listen for a click.sometimes a sensor is stuck and not relaying proper status.
Feb 22, 2015 | Bosch Dryers
Bosch maxx 7 varioperfect
On the bottom front there is a panel, that panel is the 'sump' area. Make sure that is cleaned out so that all water can eject during rinse cycle.
Nov 19, 2013 | Washing Machines
My dryer Bosch maxx 7 doesn't work
That is a bad motor. It is overheating and the overload is shutting it down. Check to see if there is lint buildup on the motor. If not, you will need a new motor.
Nov 04, 2012 | Dryers
Hi I have a Bosch WSL1662 Maxx washing machine. The spin cycle does not work properly. What could the possible cause be. I have cleaned the outlet of the washing machine and the problem is still...
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months
Jun 23, 2011 | Washing Machines
Bosch maxx 7 sensitive dryer wich stops everytime and shows that there is a problem with the reservoir
Dec 18, 2010 | Bosch Dryers
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
Bosch Maxx Instruction Manual
F:16 - Doors are not properly closed. Check the doors are closed with no obstacles.
F:17 - Water is not running. Check the tap, hose and filters. Also water pressure can be low.
F:18 - Too much water remaining. Stop the drying program and start Spin program. Otherwise something is bolcking the water exit from the machine.
Jan 22, 2008 | Washing Machines
Dryers Logo
29 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
