Question about Minolta EP1030/1030F CS/PRO Copier
TROULESHOOTING U1
MACHINE CANNOT MAKE COPY
  • Minolta Master
  • 6,680 Answers
In user mode touch the stop clear to exit.
Posted on Feb 07, 2015
I keep getting a u1 code and my machine makes a horrible banging noise and I have to quickly pause it. Can someone tell me what is wrong with it?
U1 is unbalanced load. Try moving the clothes evenly in the washer if it is a top load. If it is a front load or top load try removing some of the clothes. If nothing works then it is more than likely bad tub supports
Jul 04, 2016 | Washing Machines
What is a U1 code
U1 is a filling fault , so you will have to check the water supply into the dish draw is turned fully open and the hose is not damaged or kinked . Ensure the spray arm inside the draw is free to rotate and clean out the strainers inside as well .It would also pay to check the levels on the machine .If you run the dishwasher whilst using water else where the water pressure may also be dropping to much or even changes in temperature may effect it .
Good luck
Aug 29, 2014 | Fisher and Paykel Dishwashers
How do you fix Error code U1
U1 is displayed on the LCD as a "no tap" symbol. (time out on fill is after 175 seconds)
Possible causes:
• Water turned off
• Insufficient water supply pressure
• Blocked water softener filter (if fitted)
• Spilt rinse aid causing over foam in tub
• Incorrect detergent being used
• Motor rotor
• The machine is siphoning
• Inlet valve has failed
• Controller
Jul 08, 2014 | Fisher and Paykel 23 in. DD603H SS...
TROULESHOOTING U1
You are in the user mode touch the stop exit button to get out of the mode! Holding down the exposure control arrow to the left and powering on is the way to enter the user mode.
Jan 22, 2013 | Minolta EP1030/1030F CS/PRO Copier
Sharp Al-800 H4 Error Code
Press : CLEAR key - INTERRUPT key - O - INTERRUPT key.
The copy quantity display goes off and the machine is ready to receive input of test command number.Enter the two digit number to select the test commands.The test command number entered will be displayed in the copy quantity display.Press the PRINT switch.The operation corresponding to the entered test command number will be performed.For the test command 13 and 14 since test commands 13,14 are used to clear the contents of the diagnostic status (U1,H3,H4)stored in the LSI,the diagnostic mode will be automatically canceled after completion of the test commands.
Jul 30, 2009 | Toshiba e-Studio120 Copier
Asking to format
If this is a new floppy then its advisable to format it.
But if it has been formated before and the message still comes on then ignore it.
Also if you're denied access (Copy or Read) to the floppy then please reinstall the drivers and the floppy drive again using the installation manual
May 21, 2009 | Sony (MPF82E-U1) External Floppy Drive
Have a xerox 5314. I get a u1 code when trying to
Hello sir; U-1 means main drive unit have problem such as main motor, gears, belt etc.
May 13, 2009 | Xerox Office Equipment & Supplies
Problems with my MODI XEROX 5216
It can not copy. When I power on after 30 seconds the copier show U4 in the screen and do not work.
Mar 13, 2009 | Xerox Office Equipment & Supplies
26 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
