Question about Electrolux Freezers
Electrolux upright freezer euf2900x - Electrolux Freezers
Why is my Electrolux freezer outside walls hot
The condensing coils are embedded in the walls of the freezer. The freezer uses the wall as a heat sink. This allows the freezer to dissipate the heat that has been pulled from inside the freezer to the area outside of the freezer.
Jun 15, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Where is the thermostat on my electrolux freezer (E32AF75FPS)?
Hi spazmodius, thank you for your post! This particular model has a thermistor to relay the temperature inside the unit to the Main Control Board. The thermistor is located behind the evaporator panel, to the right of the evaporator. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Aug 03, 2013 | Electrolux E32AF75FPS Upright Freezer
My Electrolux upright freezer Model GLFU1467FWO Serial No WB61740462 ..the temperature warning light kept going off, so kept resetting it, now there is no temperature light at all, the freezer is stil
Check the condenser grille is clear and clean, and all fans are working. Get a cheap thermometer to keep in the freezer and check it from time to time.
Jul 21, 2012 | Electrolux Freezers
The freezer is geting high temperture, it could be set down.
find the adjustment knob, set it to a desired tempreture and allow 24 hours for adjustments
Mar 02, 2011 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Exclaimation triangle red light is on - Electrolux CUU6174
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 07, 2010 | Electrolux 3.53 cu. ft. / 100 liter...
Upright freezer not cooling adequately
Go to there website and see if you can find your model. You can also contact them from there.
http://www.aeg-electrolux.co.uk/node145.asp?CategoryID=2595
Also get yourself a stand alone fridge and freezer thermometer - leave it in for an hour -that will establish what the temperature really is which will help in diagnosing the cause.
Also trying unplugging it for 15 minutes so the display board loses power - then plug it back in - sometimes that will reset it.
May 04, 2009 | AEG 7.59 cu. ft. / 215 liter Upright...
Its not freezing!! keeping things cool, but not freezing
I would definitely start by checking if the fan is working. Note that the fan is switched off when you open the door, so you need to press the door switch and then check if it is working. If not, that will be the problem.
Apr 15, 2009 | Electrolux 3.53 cu. ft. / 100 liter...
Freezers Logo
56 people viewed this question
Top Electrolux Freezers Experts
AJMAL KHAN
Dennis Boxerman
Wayne Tolonen
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
