Question about Cisco 7912G IP Phone
Cisco ip phone 7911 stuck in the upgrading - Cisco 7912G IP Phone
SOURCE: Cisco 7912G IP Phone
You can not shut off CCM CSRST fall Back service. You need to either remove SRST reference in the device pool or for the phone specific configuration. I suggest you create device pool similar to one you have but without SRSR reference. Then you need to re-apply device pool in the phoone configuration and restart the phone.
Posted on Jun 09, 2008
  • 5 Answers
SOURCE: Cisco 7970 ip phone, can't pickup call
Make sure you have both phones in the same call pickup group. I have never used the group pickup button. The regular pickup button is what I use.
Just to be clear the procedure is..once phone A rings you hit the pickup button on any other phone that is in the same group as phone A. After you hit the pickup button the call will be drawn to the phone that you hit the pickup button on. Once the call is on that set hit the answer button to answer the call.
Posted on Aug 01, 2009
  • 121 Answers
SOURCE: CISCO IP PHONE 7941 -add background images (user preferences,
See Cisco's user guide regarding template modification and customization at http://www.ciscosystems.am/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/7_0/sip/english/administration/guide/7960usrS.pdf
Posted on Feb 19, 2010
SOURCE: CONFIGURE ip pHONE 7912G
My phone cuts in and out. I am hooked up to a Rogers Rocket Hub with a static ip address.
Posted on Jul 12, 2010
  • 15 Answers
SOURCE: my cisco ip phone 7960
You can try a couple of things: Unplug the power cable from the phone, hold dows the # key, and then plug the power cable in again. The phone begins its power up cycle. Release the # key after the Speaker button is no longer lit. You should see the following message on the phone: "Reset key sequence detected" Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash. If you enter this key sequence correctly, the phone displays this prompt: Keep network cfg? 1 = yes 2 = no In order to maintain the current network configuration settings for the phone when the phone resets, press 1. In order to reset the network configuration settings when the phone resets, press 2.
Or to perform a full reset: Press **#** to reset the Cisco IP Phone 7960
Posted on Mar 15, 2011
How can answer the calls away from the desk if I need to push the answer botton on the phone?
The little silver button on the side of the headset is how you answer calls when using the headset, when you get a call just press the button, this is also how you hang up
Oct 07, 2014 | Plantronics CS540 with HL10 Wireless...
How to configure NORTEL T7208 with cisco CME
No, the nortel phones you have are digital. Cisco is an IP system (not very good either)
Nov 17, 2012 | Computers & Internet
Need to reset phone cisco7962
Hi Gtrcop
Restart phone by unplugging power cable
When you see cisco logo press and hold #
Headset, Mute, and Speaker buttons begin to flash in sequence, release #.
The phone will prompt for
HTH
-Karthik
Oct 16, 2012 | Cisco 7962G IP Phone
How to upgrade to SIP Firmware on Cisco 7945G
This process should work for you http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
Cisco Telephone Power Brick
Sep 08, 2012 | Cisco 7945G IP Phone
My Cisco IP Phone 7945G keeps rebooting after I did a factory reset. Is there a way to fix this?
According to Cisco, when initiating a factory reset procedure certain information from the IP phone is erased while other information is reset to the factory default value, as shown in the list below:
Information Erased:
  • CTL File (Certificate Trust List)
  • LSC File (Locally Significant Certificate)
  • IP Phone Call History (Calls Received, Placed, Missed etc)
  • Phone application
Information Reset to Default:
  • User configuration settings (ring tone, screen brightness, sound levels etc)
  • Network configuration settings
t is highly advisable to follow the firmware upgrade procedure in a non-working environment to ensure other phones are not affected (in case of an accidental reboot), and to avoid the freshly factory reset ip phones obtaining the working environment's settings.
Please use the link below and follow the instruction http://www.firewall.cx/downloads/cisco-tools-a-applications/cisco-ip-phone-a-ata-firmware-downloads.html
Aug 28, 2012 | Cisco 7945G IP Phone
My Cisco IP 7960 Phone is stuck at "configuring IP"! What is happening? I need to get it fix asap :(
it would appear your phone is not getting an address from your DHCP server, i would start by plugging in a laptop to see if that gets an ip address
Hope this helps
May 21, 2011 | Cisco 7940 IP Phone
I HAVE ROUTER CISCO 2503 VERSION 11.(10c) I AM PREPARING MY CCNA SECURITY ,HOW CAN I UPGRADE IT TO VERSION 12
For Software Order. To order an upgrade, please use the product numbers beginning with "FL". These product numbers, known as Feature Licenses, enable your order to be processed as an upgrade and not as a more expensive new-system purchase. Ordering Example
blank.gifYou are running the IP feature set (S25C-12.0.1) in a Cisco 2500 series router
blank.gifYou want to upgrade to IP PLUS (S25CP-12.0.1)
Use FL25-P= to order (see the price list for all available product numbers)
Example 2: A Complex Upgrade Order More than one Feature License may be required in ordering an upgrade. Ordering Example
blank.gifYou want to upgrade from the IP feature set (S25C-12.0.1) running in a Cisco 2500
blank.gifYou want to upgrade to the IP/IPX/AT/DEC PLUS (S25BP-12.0.1) feature set
You must use two Feature Licenses:
blank.gifOne to upgrade from IP to IP/IPX/AT/DEC (FL25-C-B=)
blank.gifOne to add the PLUS (FL25-P=)
For Upgrading Procedure Please check the below link.
The procedure is for all the Cisco Router
Upgrade procedure
Feb 12, 2011 | Cisco 2503 Router
How can I upgrade my frimware on the Cisco 7960, it is a 3 and needs to be 7?
Best and easiest way is to plug it into a newer callmanager. The firmware will be upgraded regardless of wether or not it is able to register.
Sep 02, 2010 | Cisco 7960 IP Phone
Cisco 7912G IP Phone Logo
332 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
