Question about Cyberhome CH-DVR1500 DVD Recorder
Problems with dvd reading
I am using the cyberhome dvr 1500 and im having trouble with the dvds. im using the dvd r from verbatim and dvd rw from maxell and the recorder doesnt recognize it. in the instructions it said that any kind of dvdr or dvd rw can b used. what brands of discs can i use on this machine?
  • Anonymous Dec 19, 2007
    When reading disk ( I have about 5 types including movies) dvd Recorder states NO DISK no matter what I have tried. I let maching rest over night and no luck. Even Cyberhome disks will not work.
    Where can I get this machine repaired?
I HAD THE SAME PROBLEM WITH MY LG DVD RECORDER NOT EXCEPTING CERTAIN RECORDABLE DISCS . NO GUARANEES BUT TRY GOING TO YOUR SETUP MENU AND RE-SET THE ORIGINAL FACTORY SETTINGS FOR THE RECORDER THEN PUT A DVD CLEANER DISC IN YOUR RECORDER TAKES ABOUT TWO MINS TO CLEAN UNIT THEN TRY A BRAND THAT DOES WORK IN YOUR RECORDER OTHER THAN VERBATIM OR MAXEL . RECORD SOMETHING THEN EJECT IT . NOW TRY ONE OF YOUR MAXEL OR VIBATIM DISCS AND SEE IF IT WILL READ THIS TIME FOR RECORDING . GOOD LUCK . BEST REGARDS , blc7772001
Posted on Sep 28, 2007
SOURCE:
PIONEER DVD-RW DVR-106D will burn but won't read
i have the same problem ,but when i restart my pc ,i put the disk it can read without a doult .The problem is your disk drive can't read disk when it on windows mode ,using dos and it just fine,some kind of trouble appear cause i burn too much disk in a time and it can't read next time i open computer .May be your windows problem just restart wins then put the disk in ,if it appear the green light it mean it's reading then the green light off it's mean it had identify the disk and does read it
Jun 26, 2009 | QPS Que! CD-Rewriter CD-RW Burner
Dvd player doesn't recognize the dvds
Found this article in a customer report about having problems with using different types of dvd's in the CyberHome players. The responseis from the now defunct CyberHome customer service department. I hope this helps you with your problem.
we do not recommend the use of Maxell, Memorex or TDK brands of
> discs because recent testing has shown them to be incompatible with our
> units.
> There are many different types of disc media available today, and not
> all of them are compatible with CyberHome equipment. And while there
> may be others brands of disc media that will perform quite well in our
> units, there are others that will only work on an intermittent basis.
> We have tested the following brands, and found them to be the most
> compatible with our equipment:
> Verbatim, Great Quality, Ricoh, Ritek, Nanya, RiData, Daxon, CMC
> Magnetics Corp, Info Disc, Intenso, Imation, MBI, MCC, and Medianca
> seem to work the best in our units.
Apr 06, 2009 | Cyberhome CH-DVD 300 DVD Player
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
PIONEER DVD-RW DVR-112D problem
have you tried cleaning the lens? i also had this experience with my dvd rom and what i did, was cleaned the lens.
tell us what happen after you clean it ok.
Jan 14, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
DVD RW
YEP the firmware does not support that type of media
you can try upgrading the firmware but that may not help
eighter use a different media of change the drive
Dec 21, 2007 | Pioneer DVR-109 DVD±RW Dual Layer...
My New Cyberhome DVR 1600
change all the caps in the power supply, clean the optic lenze, q-tip damp use the other end dry to wipe lenze, if that dont do it bin it, regards mark
Oct 30, 2007 | Cyberhome DVR 1600 DVD Recorder
Not playing dvd's, but will play audio
I had a similar problem about 2 years ago, if not exactly the same. At that time I was able to call Cyberhome and got a helpful person on the other end. He explained to me that some brands of disks do not record with the 1600. He told me to use Verbatim disks (+R or +RW of course). I have had no problem with the unit at all since using Verbatim disks. I have also found that Imation works well also, at least the +RW's. The unit will not format a Maxell disk. Hope this helps.
Mar 02, 2007 | Cyberhome DVD Recorder - DVR1600
Dvd compatibility issues...
You should try updating the firmware in the burner. http://www.cdrinfo.com/Sections/Reviews/Specific.aspx?ArticleId=16989 http://wwwbsc.pioneer.co.jp/product-e/ibs/device_e/dev00001r_e.html scroll down a page or 2 and you will see the firmware upgrade for your model. Good Luck, Tim
Feb 07, 2007 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Cyberhome DVR 1200 acting up; won't format new blank dvds; says no disk,etc
Cyberhome has gone out of business in the US. My DVR 1200 stopped working but I was able to repair some capacitors on the power supply to get it going again. You can find more support information about the 1200 and 1600 on these websites: http://cms-system.cyberhome-dvd-help.com/modules.php?name=Forums&file=viewtopic&p=14183 or www.nerd-out.com and search for Cyberhome.
Jan 02, 2007 | Cyberhome DVR 1600 DVD Recorder
Problems recording DVD-R 16X
Try this download page to update your firmware from 25/10/05, so if you bought your writer before this date maybe this will work, otherwise buy 8x discs. http://sony.storagesupport.com/dvdrw/firmware.htm#710 The faster the discs are burned the more chance of errors there are, you should write at slower speeds for better quality.
Oct 27, 2006 | Sony DRU-710A DVD±RW Dual Layer...
Open Questions:
See all Cyberhome CH-DVR1500 DVD Recorder Questions
Cyberhome CH-DVR1500 DVD Recorder Logo
183 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
