Question about HP Photosmart 6520 e-All-in-One - multifunction printer / copier / scanne
Problem printing document in landscape mode with photosmart 6520
Page and font size is reduced leaving a space at rhe bottom of the page
SOURCE: Printer only prints half a page
When I print a page off of the internet it won't print off the whole page.
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: Can't print because of Error-offline status.
I found out that the IP address on the printer was different from the IP address that was available when the printer was first installed. After spending days trying to fix this, it was resolved in less than two minutes.
Go to the Printer Folder in the control panal and choose to Add a Printer. You will see the option to add the new printer ( wireless). Chose to install, and it will install the printer under the new IP address. It worked instantaneoulsy.
You also need to make sure the IP address is inputted into the printer ( check your guide for how to input the IP address)
What I dont know how to do is to keep the IP address static. Afger, it is not practical to do this each time it changes. If only the last digit changes, it may be as easy as switching to the printer available under the current IP address.
Cheers,
DeniseA
Posted on Mar 14, 2009
PeteG0429
  • 34 Answers
SOURCE: prints extra blank page for every one page of printed material
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
Posted on Apr 01, 2009
PeteG0429
  • 34 Answers
SOURCE: One extra blank page coming out for each page actually printed
There you go. Good luck!
Posted on Apr 14, 2009
PeteG0429
  • 34 Answers
Here you go...
Posted on May 18, 2009
Suddenly the font size on my printer increased greatly.How can I get it back to normal????
Printers do not understand fonts. They print dots, and they print them wherever the application that created the document, modified by the print spooler settings tells them. Thus there is nothing wrong with the printer. Check the print driver (spooler) settings. Do you have them set to "enlarge to fit page/shrink to fit page"? Do you have the wrong size paper selected? That, along with the previous problem, can cause major issues.
Sep 10, 2016 | HP Photosmart 5520 e-All-in-One Printer
My HP 4300 all in one printing reduced size of original document
Have you tried checking on the page, that when you select print, it shows how many pages you want, portrait or landscape, on this page it should also have the proper ratio to print, ie.,100% vs.say 75%. Check to see if it's still at 100%, it's possible that it reduced size to fit a page and didn't change back
Jun 12, 2014 | HP Officejet 4300
I have a photosmart 4650...when I print from a web page, the print is so small I cant read it. How do I change the font size?
Best Answer -
That entirely depends on what you are printing. A printerwill only produce what it is given.
If you are printing your own document then you change the font in the documentbefore printing or select the font before you start.
However I suspect the reason you are asking this is because you are printing apdf document from the internet. In which case the font is fixed.
If so, then you will have to copy and paste the document in to a word processorlike Word, highlight it all and the increase the font. You will then have toreformat the whole document as the increased font will throw the orginalformatting all out of line.
When you have straightened it all up then print it off.
ALTERNATIVELY, if you are printing on ordinary web page then you need to follow the below instruction
Instructions
1. 1 Go to theweb page that you want to print and right-click it. Click "PrintPreview." If you want to print part of the page, highlight the contentthat you want to print and right-click the selection. Click "PrintPreview." 2. 2 Click the "Page Setup" icon located onthe top of the Print Preview window to launch the Page Setup dialog box. Click"Change Font." 3. 3 Select the font you want to use in the"Size" window. If you want to change the font type, make yourselection in the "Font" window. Click "OK" to save thechanges and click "OK" again. 4. 4 Turn on your printer if it is not on. Click the"Print" icon on the Print Preview window to print your web page.
Sep 29, 2010 | HP Office Equipment & Supplies
Hp1100, an A4 format page in pdf is being printed on two pages. does anyone know whats causing this, reagrds
In the printer properties select "Fit to Page" and this will ensure that it will print it all in one page. The reason it is printing two pages, is that when the document was made, they didn't finalise it properly and/or some of the document was over the page, sometimes a Font change, is all that may cause it. So as related always select, fit to page, or often there is a print Percentage size, so you can fit it all in. Either that or edit the document and rid, the second page, by making the font smaller,different type face, take out spaces, whatever is required to rid, any second page then save as an A4. Then you wouldn't have to use the % print, or fit to page.
May 06, 2010 | HP LaserJet 1000 Printer
How do I enlarge a page so I can read it? When printing something from the internet, how do I enlarge the print? I have printed a pattern and cannot read it.
There's no option to enlarge the font or text of what you are printing from the Internet. What you need to do is to copy the page that you would like to print and then paste it in a Word document.
From the Word document, there's an option for you to change the font size and color.
Have a great day!
Dec 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Dec 25, 2008 | Computers & Internet
Printer switching orientation
Make sure that manual feed is set to letter, on the printer front panel. This is a tabloid printer, so letter size sheets are fed long edge. The cassette will print okay because the media size info for the cassette is read by the printer from the cassette cams.
Dec 21, 2006 | Xante 4G Printer
HP Photosmart 6520 e-All-in-One - multifunction printer / copier / scanne Logo
81 people viewed this question
Seeker5211
Seeker5211
