Question about GE WBSR3140DW Top Load Washer
What is the ge washer model number compatible with ge dryer DCLR33ET?
DCLR33ET
2 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: Purchased a damaged GE dryer. Model and Serial number removed.
Model tag is inside door frame or at the bottom corner on the side. It may have been removed or not replaced if the front panel was replaced, Eric
Posted on Jul 07, 2009
Is the motor from an AEG L16820 Washer Dryer compatible for use in an AEG L16850 Washer Dryer
The two model nos you quoted do not in general have interchangeable motors however....
The exact motor depends on your product number not your model number. Look on the plate on the machine and check on aeg's website or a spares website
Jul 22, 2014 | AEG L16820 Front Load Washer
Tip
How it works: Late model Ge top loading washer
The late model top loading GE washer is much different than it's original models that were so much more dependable than these newer ones are. To access the innards you must forst remove the front panel. Older models had the top pop up first but these newer models have the top bolted down. To get the top up you must first remove the front panel by using downward force on the top between the tiop and the front panel. It is not easy even for eperienced techs but cuss it a minute and it will come off. Once it is off you will notice the washer has an elecetric pump. Strings and junk get into this pump. It is easy to take apart and cleanup. The tub is suspended on 4 rods and the lateral movement is kept in check by 4 rubber cord mounted to the top called bungies. The motor and tranny can easily be accessed by removing the tub from the washer. After disconecting the power cable and pump the tub lifts out. Not all GE washers use the same motor or the same transmission method. Some do not even have a tranny. I have some GE washer service manuals.
GE front access late model washer
on Dec 13, 2010 | Washing Machines
Remove and replace heating element in GE Dryer
Not enough info! what is model number?
GE dryers has many models and each one has different procedure to remove heating element
Apr 20, 2014 | GE Washing Machines
Replace bearing in a GE SXH47eg1WW dryer
The bearing is the plastic which holds the front glides. It just snaps in place and is easy to remove using flat blade screw driver. The bearing has 3 or four glides which are purchased separately. The rear of the dryer also has a bearing which is plastic part number WE3x75 on the old models, newer models use a different number.
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gib
Apr 14, 2014 | GE Dryers
Locate model number on a GE stackable
look on the front of both items if not look for a label it may be in the door area or on the rear
Aug 25, 2012 | GE Washing Machines
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
1989 (?) GE Spacemaker washer in a park model trailer has a cracked plastic air pressure tank. No model # on washer, how do i get parts.
You do need the model number to order parts...typically on a stacked unit the model number is inside the dryer door
Sep 08, 2011 | GE Spacemaker Washer and Dryer Electric...
Jul 07, 2009 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
GE WBSR3140DW Top Load Washer Logo
19 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
