Question about Dell 5100cn Laser Printer
Error #006-370 Restart Printer
I have numerous times, it clears and then it sames the error again. I have unplugged, I have rebooted.
    New Friend:
Posted on Jul 04, 2013
    Genius:
  • 2,120 Answers
Call a Lexmark printer repair company
Posted on Jan 28, 2009
How do I fix error code 0x97 on Epson printer
0x97 is a scanner circuit board error. You can reset your printer by unplugging it from the wall for a few minutes, and then trying again. Unplug is not the same as "turn off". Other than that, service center is your only answer.
Jul 05, 2016 | Epson WorkForce WF-7620 Wireless Color...
ADF error-says to clear paper jam and restart there is no paper jam.
If you are 100% positive there is no left over paper jammed, then most likely your paper feeder needs to be lubricated.
Mar 30, 2015 | Epson WorkForce 545 Wireless All-In-One...
Y - CRUM Error / Error 093-950 Restart Printer
093-950 Y - CRUM Error
Error 093-950
Restart Printer
The yellow toner Smart Chip error is detected
Error with detecting or defective yellow toner cartridge. Replacing cartridge should correct it.
Paul
Nov 25, 2013 | Lexmark X560n Laser Printer
Y CRUM Error Error 093-950 restart printer
If new, did you remove the safety paper?
Nov 25, 2013 | Office Equipment & Supplies
My printer says ,"unable to clean refer to users manual",but cannot find any reference to the problem. hope you can help. thanks peter
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 48 - defective print head cable or circuit board.If the error is 46 the waste ink tank is full.Follow this:
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value
which is Iassume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.
After you have entered this combination, the purge numeric value will be reset to 00000.
5.Restart printer
Nov 30, 2009 | Brother DCP 115C All-In-One InkJet Printer
Cannot cleaan printheads
Did you mean "Unable to clean"?If it's that follow this:
full.Follow this:
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value which is Iassume the number of times the printer had cleaned.
5.Restart printer
Nov 24, 2009 | Brother DCP 115C All-In-One InkJet Printer
Routine Maintenance
5.Restart printer
Nov 18, 2009 | Brother DCP-110C All-In-One InkJet Printer
Message comes as unable to clean ... cartridges are brand new no paper jam in the system the model is DCP 340 CW
4. Press 'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.After you have entered this combination, the purge numeric value will be reset to 00000.
5.Restart printer
Nov 16, 2009 | Brother DCP-340CW All-In-One InkJet...
My brother dcp 110c printer is unable to initiate and refers to routine maintenance - it does print out test sheets however and I have undertaken routine maintenance - not sure what else to do
5.Restart printer
Nov 13, 2009 | Brother DCP-110C All-In-One InkJet Printer
Installation problems with HP dj 460c drivers
unplug the printer then install the drivers then reboot the PC then plug in the USB printer to USB port then insert again the CD installer..if their is same the problem you need to re-install the OS/windows...good luck
May 27, 2009 | HP Deskjet 460c InkJet Printer
Dell 5100cn Laser Printer Logo
2,528 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
