Question about Honeywell Programmable Thermostat Heater
Honeywell rth2300/rth221 master reset
Need to reset
2 Suggested Answers
239gatorac
  • 1202 Answers
SOURCE: HONEYWELL THEMOSTAT RTH2300/RTH221 SERIES Display shows each number obscuring another number. lmpossible to program with all those numbers.
Remove the face plate and be sure where the conductors enter one another are straight and in good condition. Also be sure it's going on easily, meaning wires are clear and screws are all the way in etc. Hopefully an easy fix but may need to replace. Good Luck!!
Posted on May 12, 2017
Cannot change the cooling thermostat from c to f for rth2300/rth221
go to the menu and touch to change the Ceantigrade to Fahrenheit.
May 20, 2014 | Heating & Cooling
How to wire a honeywell rth2300/rth221 to a five wire connection
I am not familiar with this particular thermostat; however, here's some general information; I hope this solution will help you troubleshoot.
Multiple Thermostats set in 1 zone will conflict; the one with the lowest setting will be the determining Thermostat. Here's an option you can try yourself; my solution is 'hard reset' the thermostat - afterwards, i'm outta options. invest in external thermometer battery/natural types; & manually turn t-stat ON or OFF; Additionally, keep an eye on how much draw your AC is doing on your meter.
setOFF manual; however do NOT change settings or power-off t-stat. I'd keep it on what you had intended it from day1. However, some may debate to turn everything off beforehand. personally, myself, poweringOFF the switch connected to your t-stat works. Remove battery and reinsert inverted; wait (5sec-1min); remove; wait 1min ('debatable' timeframe 5sec - 1min); reinsert batteries correctly; if you have a programmable thermostat; do the same with the hit 'reset filter' held down & wait 5-sec1min; observe roomTemp reading. May I suggest to keep an extra thermometer around to determine if temperature reading from the thermostat correct? Friendly reminder to turnOFF 'auto' mode during this hard reset. If reset requires reprogramming your t-stat, do whatever required to set your desired setting. cheers. best of luck.
May 11, 2014 | Honeywell Programmable Thermostat Heater
5 ton goodman package unit not coming on
If you look on the install manual. It says it will work for a heat pump without backup heat. No heat strips.........If you do not have strips the guide says as follows
"PLACE A JUMPER (PIECE OF WIRE) BETWEEN Y AND W IF YOU ARE USING A HEAT PUMP WITHOUT AUXILIARY/BACKUP HEAT." if this dosnt work check the fuse in the air handler you may have blown it if you did not turn the unit off before installing.
Mar 25, 2014 | Goodman Heating & Cooling
Honeywell RTH2300 says Heat On, but furnace isn't running.
Your tstat is not the problem. I've not yet worked on an oil furnace. I'm way down south. But either way, if your tstat was calling for heat(heat on), and you pushed a reset at the furnace, more than likely that reset is a safety. OK to reset, but now what ever that safety is preventing from happening, has failed and can not be reset until repaired. The reset should be an automatically opening switch upon unsafe operation. And manually closed to "reset" the safety. That safety is connected to something that is not working properly. Hope this helps!
Mar 02, 2017 | Honeywell prgrammable thermostat RTH2300B
Blower runs continously....
Hi Kathi,
I think its thermostat or ,thermo sensor is out of order and if it is controlled by electronic circuit it can be faulty.
another thing sometimes output contact relay for motor is faulty it want turn off itself when the circuit energize the coil.
please call electrician who can handle.
regards,
nuwan.
Jan 10, 2014 | Honeywell Programmable Thermostat Heater
Need to know if it will work
Think you need a different thermostat...you will need one for line voltage, not low voltage.
Dec 08, 2013 | Honeywell Programmable Thermostat Heater
Installed the Honeywell RTH2300/RTH221 but the old thermostat was removed by someone else. Since the original wires were not labeled, I simply attached them to the new thermostat by following the letters...
This appears to be a thermostat installation that was made without regard to wire code. The Honeywell material I have suggests it may be necessary to check connections at the furnace end and work back to the thermostat. There may be compatibility problems between the number of wires in the old installation and terminal connections in the new thermostat. Honeywell may be able to help at 1-800-468-1502.
Oct 29, 2013 | Heating & Cooling
Yes,a little more inf.that ight help solve my problem a little quicker.let me start from the begining.my wife kept switching from heat to air until my themostat finally stop working.it use to be hooke
Only the original new manual will give you the wiring. The bad news in manufacturers do not always use the t=same colors to d the same things. God Bless
John. Same happened to me and I guessed till it started functioning properly. Sorry
Apr 16, 2017 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
251 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
