Question about Eiki EIP-3500 DLP Projector
Faded color display
The bulb states it has 57% life but the display is not crisp it appears very muted or faded and the colors are not correct pink is showing up as blue, red it brown, green is yellow, blue is grey.
  • 2,237 Answers
Replace the colorwheel.
Posted on Nov 18, 2009
Samsung clx 3185 printing is all faded, colors and black
When you go to print, your printer driver should have quality options. Make sure you're not using "economy" or "draft" mode. Try "quality" mode.
Jan 19, 2015 | Samsung Office Equipment & Supplies
Does an old PHD cause faded colors?
the PHD transfers the image to the printed page and when it starts to go bad the images can become dull or faded and even blurry or totally missing. Id recommend the PHD be replaced and it should resolve your issues.
Feb 24, 2012 | Dell 2135cn All-In-One Laser Printer
Is the picuture tube messed up when you see double people and the color is faded
That usually means your convergence ics are going out. Replacing those will get rid of the double imageing. If the color is faded realy bad that means your tubes are going bad. That repair is pretty costly. Tvs over ten years are usually money pits.
Mar 25, 2011 | Sony KP-57WS500 57" Rear Projection...
This printer has stopped printing reds and oranges correctly ? they are faded. Changed the toners & no difference
Print a "Config Report" from the printers menu...If u notice that the fourth square on the left side (fourth being the bottom square) for Magenta (reds and orange) is missing or very faded, this could indicate that the optical mirrors inside the printer have to be cleaned...Design flaw. ESP..if changing toners doesn't work and your your faded issue is with Magenta (Pink, red, or orange) colours are the only faded ones...With this design flaw in the optical mirrors, magenta mirror is the first to be affected!
Hope this helps!!!! I work in the industry :)
Feb 22, 2010 | HP Color LaserJet 2600n Printer
The color has faded . I replaced the bulb the problem persists!
Light Engine is Bad, If you had said TV was making loud whistling sound then it would be Bad color Wheel
Sep 27, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
My dell latitude D830 display colors have faded.An
I would check your graphics card control panel. You may have (or someone else) set the contrast or some other setting to low or high. If you are using nvidia you can run the optimization wizard.
Mar 12, 2009 | Dell Latitude D830 Notebook
Color intensity= poor
Shake the cartridges well, it seems that they become dry, try to replace them and check again, go to driver there is setting makes u clean and test the nozzels which makes the color more rich and at the same time it check the state of the cartridges.
Best Regards
Mar 11, 2009 | HP PSC 1210 All-In-One InkJet Printer
Faded red / pink on HP Color Laserjet 2605
you have to clean the image mirrors you can find a how to guide on hp's web site titled "fading red tones on color laserjet2600' process takes about 30mins to do.
Nov 11, 2008 | HP LaserJet 2605DTN Color Printer
Windows Looks Faded
normally, this indicates that the color settings in Display properties are set to a lower than normal setting
It should be 32 bit true color
Jul 27, 2008 | Microsoft Computers & Internet
Printer color problem
The ink cartridge cleaning process can be performed even with the alignment message showing in the display. Follow the steps below to perform an ink cartridge cleaning process from the front panel:
  1. On the front panel, press Menu or Setup (depending on the model).
  2. Press the Right Arrow (>) until Maintenance or Tools appears, and then press the Enter or OK .
  3. Clean ink Cartridges should appear in the display. Press Enter or OK to begin the cartridge cleaning process. A page will be printed during the cleaning process with all of the colors on it. If any of the colors or the black are missing, faded, or streaked on the alignment page, there is a ink cartridge problem.
Nov 30, 2007 | HP PSC 2110 All-In-One InkJet Printer
Eiki EIP-3500 DLP Projector Logo
417 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
