Question about Dell Dimension 2400 PC Desktop
PC keeps booting but doesn't start up
My PC boots up but doesn't start up Windows, once it's done booting it restarts itself.
    Problem Solver:
  • 6 Answers
Easy fix! Put the windows boot disk in the optical drive. It will either start up of you can re-install windows. Easy Solution!
Posted on Jan 27, 2009
How do i get missing ntldr back
you are missing a key boot file for windows that is special to XP.
Load your installation disk.
restart your computer and when the F2 setup appears in right bottom corner (right after starting) press the F8 key (couple of times) and choose CDrom drive. (if you miss, try CTRL ALT DELETE--to reboot and try again.
(if that does not work, you will have to go into F2 setup and tell the computer to boot from the CDROM--you will find it by looking on each tab for a list of CDROM, Hard Drive, and listing of boot disk priority. Save you change by exiting BIOS set with F10.
At this point you can choose R for repair.
windows should repair itself. Once done, PC will reboot and you should be good.
** if other files are suddenly missing or other weird things, I would recommend a new install of windows. You should have up to date files for antivirus and malware.
Jul 14, 2014 | Dell Latitude D 600/610
I tried to install windows 7 on my HP Pavillion DV9, but it's not booting from CD-ROM, i tried using a USB CD-ROM, but it's still not booting. pls I need assistance.
Try to check if the windows 7 disc that you are using is not just an upgrade disc. Make sure that it is a bootable disc. Try to use other bootable disc to test. Also make sure that the boot device priority is set CD/DVD drive.
Hope this helps.
Jun 06, 2011 | Computers & Internet
I can't start windows normally, when turn on the power it shows startup repair recommended. if choose that nothing open, just black screen. how to fix this problem.
Normally computers do have the repair option, but usually it does not work or if you have formatted your PC and changed the OS.
The best way to get it repaired is to boot from your Windows CD. Once booted from the CD, you will have the choice to repair Windows. Just select this option and it will correct the problem.
Once done, your computer will restart and you should not get this message anymore.
Hope this helps!!
May 15, 2011 | Computers & Internet
We have desktop xp and it is running on safemode how do we take this off
You can't take off Safe Mode, it's there for your protection. However, if you want to boot into Normal Mode, shut down the computer. When you hear the computer beep, start tapping F8 on your keyboard. Keep tapping it until you reach the Advanced Options menu. Once you've reached this, just select "Start Windows Normally".
Now it will boot you into Windows on Normal Mode, not Safe Mode.
Jan 01, 2011 | Computers & Internet
How to reset password for toshiba laptop a210
I assume you mean the pasword to enter your operating system. If this is the case, when you start your pc, press F8 to enter windows start menu, select Safe Mode, when windows boot, go to control panel, users, and delete any passwords. Once done, restart your pc, the password will have been removed and you should be able to start windows with no problem.
Good Luck
Aug 15, 2009 | Toshiba Satellite Pro A210-EZ2202X...
CPU upgrade problem
Hi there
what are your pc specs , like ram ect. So we can find out what is wrong. please check your cpu settings and reset the pc bios to see if that hasnt solved the problem
Nov 12, 2008 | AOpen AK77-8XN Motherboard
Reformatting problem
Do you mean that you are re-loading windows? if you are when it reboots after re-loading and it says boot/start with cd-rom support do not press enter again or anything else for that matter because if you do it will keep taking you through the whole process again. Once it has loaded and reboots do not press anything it will start windows( even though it gives you the option to start with cd-rom support - just ignore it), itself and take you to the welcome screen etc... once this happens you can take the disk out.
Oct 25, 2008 | Computers & Internet
Win xp instalation
Make a windows 98 startup disk by downloading it from here . Once you haver done that turn off the acerpower insert the disk and turn it on (make sure its set to boot from floppy disks in bios setup) Choose the option start computer with cd rom support. Now after about 1 minute youy should see a:\. Type in a:\fdisk and then choose yes and then create a partiossion using the prompts given . Once you have done that and its finished it should say you must restart this computer so restart it. Then boot from the floppy disk again and when it coms to a: type FORMAT C: and then press y. Once its done take the floppy disk put and restart your computer with the windows xp disk in and it should start installling windows xp.
Jul 08, 2008 | AcerPower Sn PC Desktop
Does the laptop POST? does it boot up windows? or do the lights go on.... then off.... then on... etc?
if it starts booting windows then restarts itself then there is probably a problem with your windows install, it is crashing and that automatically restarts the pc.
If the lights keep flashing you probably have a hardware failure (motherboard)
Jun 06, 2008 | Gateway Computers & Internet
HP Desktop keeps rebooting itself
Hi Julie, the boot order is not correct. You need to change the order to boot to you're cdrom first than to you're hard disk drive.
To change that order go to the boot section of you're bios. Move to select you're cdrom & press enter on the keyboard & a list will open. You cam move devices up & down by pressing the + or - keys. Once you have corrected the boot order save & exit.
As the pc begins to start back up, press the F8 key every 2 seconds. A window will open, look for ( Disable automatic restart on system failure ). Choose the option. Windows should continue to load windows. If you see any error messages write them down & post them here.
If windows does not load continue following as mentioned below.
Check if the PC continues to reboot itself. If it continues to do so than you're windows boot files may be corrupted or worse. Load you're restore cd or you're windows cd into you're cdrom drive & restart you're PC. You should see. to load the cd press any key... (Press the space bar). You're cd will start to load. If you're using windows or the restore cd follow the on screen instruction to reinstall windows (ONLY). Doing a reinstall will not earse you're personall data. Do not format you're drive, (Yet). Finish installing windows. The PC will restart once or twice & you will see ( to load from CD press any key... ) Do nothing, windows will continue installing. When finished run windows update till there are no more updated. Some programs will need to be reinstalled, like printer software.
Post back if you need more help or have questions.
Good Luck Julie!
How to vote you're expert & repost questions.
Enter site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Apr 13, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
67 people viewed this question
Alun Cox
