Microsoft Xbox® 360 Core System Console Logo
A
Anonymous Posted on Jan 22, 2013
Status code 69 807b01f7 - Microsoft Xbox® 360 Core System Console
I have a 07' MK5 GTI and i need help figureing out why im getting absolutly no boost. ive used the vagcom reader and it threw some codes that i have no freaking clue about please help me.
so,you have Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle , Status: Malfunction 0010 0F-Digital Radio -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 46-Central Conv. -- Status: Malfunction ,start by repairing these codes to figure out your boost problem
Xbox 360 censored status code 080070525 how do I
Are you sure you wrote the correct status code? Status code 080070525 is not a valid Xbox 360 code.
Cheers,
Tom
Unlock htc status
To unlock HTC Status use unlock code.To buy unlock code use online unlocking site.I would suggest the site Prounlocking.com
get unlock code and unlock it.But you need to specify the country,IMEI number and network which is currently locked now.I have unlocked my HTC STATUS from Australia Vodafone network lock.
Apr 30, 2013 • HTC Status
Trouble code p2454
To Hi
I got this problem in Skoda Diesel Particle Filter, I have check the wiring all is perfect , then I have change it but the same problem .
will anybody tell me how can I solve this problem please ,
PS. after deleting the fault it came back
Regards
______________________________
Saturday,06,July,2013,17:18:03:25282
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.10.6.2
Data version: 20130531
Dealer/Shop Name: EEPROMKFZEEPROM WORKSHOP .
Workshop Code: 123 12345 023456
VIN: TMBHT61Z5A2101325 License Plate: PROBLEM
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 69 72 77
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 1010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 AG HW: 03L 906 023 AG
Component: 1,6l R4 CR td H23 5697
Revision: -------- Serial number:
Coding: 00114016032400080000
Shop #: WSC 73430 031 00999
ASAM Dataset: EV_ECM16TDI02103L906023AG 001003
ROD: EV_ECM16TDI02103L906023A.rod
VCID: 6BDFA3EE82E73246487
1 Fault Found:
7397 - Diesel Particle Filter; Differential Pressure Sensor
P2454 00 [175] - Short to GND
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 166872 km
Date: 2038.14.06
Time: 00:13:34
Readiness: 0000 0000
End ----------------------------------------------------------
I dont know the unlocking games codes for my samssung
try this code
#*536961# = Java Status Code
#*536962# = Java Status Code
#*536963# = Java Status Code
#*53696# = Java Status Code
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
HTTP status code was returned twice. What do I do? [email protected]
What status code?  HTTP always returns a status code (see the RFCs) to a browser, so this isn't an issue as such.  What gives you this message box (title and content, please) and what's it keeping you from doing?
8helpful
2answers
Http error status code 12152
The http error status code 12152 means that your internet server has been taken down momentarily for server maintenance/database/ there's a network error. So you have to wait and try again later.
Mar 08, 2010 • Yahoo Mail
1helpful
2answers
Coming up with a message saying 'Status code: 13030: says an unexpected HTTP status code was returned from your request'
http://developer.yahoo.com/yui/docs/connection.js.html
// 13030 is a custom code to indicate the condition -- in Mozilla/FF --
// when the XHR object's status and statusText properties are
// unavailable, and a query attempt throws an exception.
httpStatus = 13030;
Jan 29, 2010 • Yahoo Mail
Status codes
Go to http://www.techlore.com/article/15444/ This article has everything you will need. Also check this out.http://myweb.accessus.net/~090/sonyadj.html Good Luck and please dont forget to rate this thread.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
