Tv set picture is gone
My 36'' toshiba color tv set has lost its picture. only one line in center. is my picture tube done or is it worth repairing.
  • 227 Answers
It depends, the center line you speak of, does it go from side to side? Or top to bottom? Side to side you have problems in the vertical circuit. Top to bottom you have a problem in the horizontal circuit. Not picture tube problem. If it is an analog tv and depending on how old it is. What an estimate and the actual repair would be you are better off buying a new one.
Posted on Jan 27, 2009
7inch vertical color lines right side of screen all th time
This website has the service manual ($7.79) with instructions to diagnose the boards. Unfortunately I am afraid that the problem is not a board but the panel itself.
Thin vertical lines in the middle of the picture mean that the panel is gone. Here an example of lines from bad panel in Toshiba LCD:Line Picture. (discussion: Avsforum). Sometimes the lines can be dark or in bright color.
The panel costs $339 (LCD PANEL ASSY).
Because of the price of the panel, the TV is not worth repairing unless under warranty.
Even if the TV is out of warranty call Toshiba and report the problem. As you can see in AVSforum page above the problem is affecting many users.
If Toshiba doesn't offer special conditions on repair (or discount on new), the TV is not worth repairing. Replacement of the digital board will hardly be a solution.
Only if you have wide bands, scrambled or flickering, then the problem is digital board (main board) or panel.If you have the thin pixel lines, then the panel is gone.
Dec 10, 2011 | Toshiba 40RF350U 40 in. LCD TV
The picture with my television has gone out. The sound is fine but there's only a white line across the middle of the television. How can I fix the picture?
The Toshiba sets are well known for this problem, the tv has a vertical deflection issue caused by the vertical ic and a few small capacitors going bad, I recommend a tv technician for the repairs.
Jan 15, 2011 | Toshiba 36A40 36" TV
16 year old, 36'', analog TV, model CX35E60, with Charter cable service. The picture has a pink tint when first turned on. The pink tint lasts several minute and then will correct and the picture will be...
Your picture tube is on its last leg. Best enjoy the old girl while you can. This would be way more expensive to repair than it is worth if you can still find a tube for this set. That has been a good set to last that long. Not too many of them left out there. Thanks for using fixya.
Nov 09, 2009 | Toshiba CX35F60 35" TV
I have sound but the picture is purple and will not adjust with the remote or manually with the buttons on the tv what can I do to fix this on the philips 36pt41b129
The unit has lost its green video information. This can be a picture tube or a green drive problem. The only colors you are getting are red and blue thus the purple picture. All picture tubes have red, green and blue guns to make all the colors needed for a normal picture. It will take some troubleshooting to determine whether it is a drive problem or the picture tube itself. Have a repair shop check it out for you. A 36" TV is worth a check out fee. Thanks for using Fixya. Let me know how it goes.
Nov 05, 2009 | Philips Televison & Video
I have a 36" toshiba with a shrinking picture and is now a thin horizontal line. Can this be repaired and is it costly?
The tube on the tv is gone my friend time to look for another tv unless you want to pay more to fix it which could cost more than the tv . hope this helped
Oct 30, 2009 | Toshiba Televison & Video
No picture.Just a single line in middle of screen.
No, your picture tube is fine. This is a problem in the vertical circuit that deflects the beam up and down. This repair is fairly typical across most television brands and should not cost too much to fix. I don't want to quote another shops pricing but from us this would run about $150.00 to fix.
Oct 07, 2009 | Toshiba CF36G40 36" TV
Toshiba CF36G40 36" TV Problem
IO board has bad solder joints or is bad if you tap the outside firmly it will come on for a while
May 28, 2008 | Toshiba CF36G40 36" TV
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
Constant changes in picture colors.
It is a 20" TV set and will most likly, im afraid to tell you, cost more to fix then it is worth. The problem is a bad Picture tube, an intermittant CRT socket or the video jungle IC is intermittant. If you want to invest in an estimate, check out first if it will go towards the repair, as then maybe you can get it fixed at a good price, as long as the picture tube is not the problem Good Luck
Oct 07, 2006 | Toshiba 20AF46 20" TV
Televison & Video Logo
Top Televison & Video Experts
