Question about Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Fan not working
My Diplomat oven in now over heating because the fan has all of a sudden stop working, when it gets too hot it cuts out, what is the problem and how do i fix it? would it be an easy job?
  • 188 Answers
Test fan for resistance with multimeter or get new fan from spares at rangemaster number is 08707 895 107
Posted on Mar 26, 2009
Diplomat Gas Oven cuts off after few mins
The oven is probably overheating and shutting itself off to prevent damage/fire. If the cooling fan isn't running. Check/replace the thermostat that switches the cooling fan on.
Aug 02, 2014 | Hotpoint Diplomat Oven Grill Selector...
Diplomat ADP 5520 Stainless Steel Range not getting hot enough
The circular element that the fan sits behind heats the oven. Ensure the thermocouple is back in the right place. Too near the element and the oven will stay cool.
Circular elements can be pricey and fitting should cost no more than an hours labour.
http://www.espares.co.uk/search?SearchTerm=ADP5520%20element
Jun 23, 2017 | Ovens
Hi there i have a stoves newhome double oven the bottom oven has suddenly stopped getting hot the fan and light are still working but we have no heat.we have tried changing the thermostat but that has not...
If the fan is working o/k, then I would suggest that bthe oven fan elementt has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Dec 28, 2010 | Stoves Ovens
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
The inner glass panel on my diplomat oven has shattered. What can I do?
My Diplomat Oven Heating element (ELEHY6075) stopped working with the FAN ON combination. I replaced it with a new one and it still does not work with the FAN option. All other combinations do work. What can I do?
Mar 07, 2009 | Ovens
Diplomat ADP3702 cooling fan problem
It could be a fuse or thermal cut out, you can test it with a meter. you should have continuity through it, if not then it is faulty.
If you do not have access to meter, then if take a piece of wire and connect it to the fan terminal and connect the other end to the origin of the ceramic fuse or what ever it is, and it should work, you are in effect bypassing the part in question.
If it still does not work then you are going to have to investigate further, or call some one in.
Plz rate my solution.
Thanks.
Jan 03, 2009 | AEG B1180-4 Electric Single Oven
Fan assisted oven not working
If the fan is still working then it is the element that has gone. This is easily replaced as you only need to remove the back panel and swap the the element.
Nov 02, 2006 | Rangemaster Classic 110 (Dual Fuel) Dual...
Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
385 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
