Question about LG WT5001CW 27" Top Load Washer with 5.2 cu. ft. Ultra Capacity, 12 Washing Cycles, WaveForce
Lg waveforce won't rinse
Water comes out ot slow on rinse
2 Suggested Answers
SOURCE: washer won't rinse the water
what is the model and what is it doing
Posted on Nov 02, 2012
How do I get my lg waveforce WT5001C washer to turn on? The power went off and now the washer lid is locked shut and none of the lights are on. I checked the wall plug and it is fine.
Having the same problem with my LG WaveForce top loader. Power went off and now lid is stuck shut and machine will not turn on. Power outlet is fine.
Aug 27, 2013 | LG WT5001CW 27" Top Load Washer with 5.2...
Lg waveforce washer grinding sound
If it is just coins, I wouldn't bother. However, depending on the age and or unexpired warranty, I wouldn't jeopardise the warranty.
It could be the agitator's transmission, which if it is under warranty
should be fixed by the MFG. If out of warranty, unless you are a DIY, you need to call appliance service people. Ask the approximate price for repair. Depending on the age, it may be time to look for a lightly used replacement.
Mar 17, 2013 | LG WT5001CW 27" Top Load Washer with 5.2...
LG washer high pitch noise when water enters at beginning of cycle
Two possibilities: the water is coming in under pressure through a solenoid valve that is not fully open or the pressure pump is whining on its bearings.
Jan 22, 2013 | LG WT5170V 4.7 cu ft High Efficiency Top...
My lg model wm2277hs won't rinse water stays after washing
you need to ck the filter in the front down at the bottom left corner of the washer if it is clean you will need a new drain pump motor
Nov 02, 2012 | Washing Machines
Washer won't rinse the water
Nov 02, 2012 | LG Washing Machines
Clothes don't come clean
Can be due to several reasons but you need to check the belt if this is loose the revolution can be slow and so the agitation can be limited.
Also check the water flow for rinse and also the dispenser.
finally check if the machine is dirty
check this link for cleaning the machine
Cleaning the machine
Jun 25, 2012 | LG WM0642H Front Load
417-44052400 Fills with water, washes, drains/spins then comes to a stop. If I did the diagnostics right it indicates E11? Anybody else have this problem?
e11 is a water problem filling to slow,you could have a problem with your cold water fill line,clogged sediment in the valve or something like that,when it goes into rinse the machine uses cold water so the clothes won't wrinkle and it sounds like it's filling to slow.
Nov 26, 2011 | Washing Machines
LG WT5001CW 27" Top Load Washer with 5.2 cu. ft. Ultra Capacity, 12 Washing Cycles, WaveForce Logo
44 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
