Question about Philips Magnavox 15MF150V 15-Inch Flat Panel LCD TV with NTSC Tuner
Magnavox monitor stuck in PC mode
Stuck in PC mode. Can not access menu.
SOURCE: Magnavox MDV560VR DVD Player Stuck in Progressive Scan
Trun the DVD player on till you see the "progressive scan" screan. Hold the "stop" botton down for 5 seconds and the unit should reset to standard DVD play.
Worked for me, good luck.
Bill
Posted on Apr 04, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Progressive scan mode
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
Posted on Sep 05, 2008
Shuttle83
  • 1139 Answers
SOURCE: DEMO MODE
Hello hoz685,
push volume up
and volume down buttons at the same time
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jul 12, 2009
  • 36 Answers
SOURCE: VCR stuck in VCR eject mode
You can get the manual here. Maybe it will help:
http://www.retrevo.com/support/Philips-27MC4304%2F17-TVs-manual/id/277bh936/t/2/
Posted on Jul 25, 2010
  • 6 Answers
SOURCE: 1994 magnavox tv stuck in demo mode.
With the set ON. Press the volume up AND volume down at the same time. OR
Press the channel up AND channel down at the same time.
Posted on Oct 01, 2011
Hp stuck in configuation mode..model w2207w..tried everything..been like this 3 months...
Check if the menu button on the front, bottom edge or side edge is pressed in. Keep the monitor off of the wall or away from anything that can push menu buttons on the monitor.
Feb 28, 2015 | HP W2207 22 inch Widescreen Monitor
Desktop not accessible/ full black display
Presumably you see items on the screen while the os is loading and you are able to see the login prompts?
If this is a windows OS start it up in safe mode (tap f8 when first turned on to get a boot menu) to see what happens. Sounds like a resolution issue. If windows opens in safe mode look for evrror messages in the system logs relating to graphics gards or look at lowering the graphics resolution, also try attaching an external monitor. Post back if you get stuck
Dec 09, 2013 | Toshiba Computers & Internet
Magnavox converter box stuck in cable mode
My Magnavox STB doesn't have a cable mode. It is unclear from your description what the problem is. Is it possible you managed to tune your TV to something other than channel 3 or 4?
Mar 22, 2013 | Magnavox Tb100mw9 Digital To Analog...
The monitor's menu keeps poping up
if you manually press the button that accesses the 'menu' at other times, does it work ? (as in maybe the menu button is stuck down ?)
Aug 28, 2012 | E-Machines eMachines Desktop PC
Mistakenly change resolution...monitor now stuck
ok just restart your computer and press f8 f8 immedeatly after power on and feep pressing f8 f8 untill safe mode menu will appear. then highlight on enable vga mode and press enter then you can see the picture
Jun 22, 2010 | Samsung Syncmaster 940BW LCD Monitor
My Dell E176FPc monitor seems to be stuck in power saver mode. There is no way to access the on screen menu. When the monitor is unplugged from the compouter, it shows a self test screen with 3 colored...
Try the monitor if you can on another computer and see if it stays in power save mode. If it does then the monitor is bad.
If you try the monitor on another computer and you get video then that means theres an issue with the original computer.
Aug 04, 2009 | Dell E176FPC Monitor
Computer gets Stuck in Startup
Try tapping 'F8' as the computer powers up.
This should bring up the advanced options menu.
Highlight 'Safe Mode with Networking' +enter
Let the PC boot into safe mode
Then click
'start'>>programs>>accessories>>system tools>>system restore....
Pick a restore point before the problem started and let system restore run its course and reboot the pc.
Mar 14, 2009 | HP Pavilion F50 17" Flat Panel LCD Monitor
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
Monitor displays 'user mode' contrast icon @ 89%
Colin
If you can access the on-screen menu (see link below for manual) try and reset to factory settings.
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00385928/c00385928.pdf
If that doesn't resolve the problem, then also check and see if any of the control buttons are stuck, (Press button them flick finger away to try an release a stuck button)
If issue still exists, you can consult a TV repair shop, but essentially, then monitor is uneconomically repairable and it would be more cost effective to just replace it with an LCD monitor
Jul 24, 2008 | Compaq CV 7500 17" CRT Monitor
Magnavox television stuck in demo mode
My wife somehow put our Magnavox TV into demo mode too...
Plug in the set. With the set ON. Press the volume up (+) AND volume down (-) at the same time.
This worked to get it out of demo mode!
Jan 03, 2008 | Televison & Video
Philips Magnavox 15MF150V 15-Inch Flat Panel LCD TV with NTSC Tuner Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
