Husqvarna Viking #1 blown fuse
You will most likely find that ALL of the "better" manufacturers; Bernina, Husqvarna, Pfaff, will not sell proprietary parts to non-brand dealers. Ultimately, this protects the customer.
With that being said, chances are the problem you are having is NOT a bad circuit board, but a bad power supply. But, since you don't trust your local dealers, find a dealer that is not so local. A two hour car ride is going be a lot cheaper that replacing the wrong part, and NO dealer will return your money on a part that the customer diagnosed as being faulty. I assure you, a Viking dealer somewhere will help you with your problem. You might want to try a Pfaff dealer. They can sometimes obtain Viking parts.
I would try replacing the power supply first. Its a cheaper priced part, and more likely your problem. Its also easier for DIY'ers, but extreme caution must be taken to ground yourself to the machine. Static is always a concern with electronic sewing machines, and even more so this time of year. Proper grounding equipment should be worn while performing any internal repair or adjustment in any electronic machine.
As far as replacing the circuit board yourself, if necessary, also be very careful when disconnecting and reconnecting wires. The connectors are very small and bend easily. Also, care should be taken when tightening screws. Overtightening can cause faults within the circuit board by cracking the solder paths or just plain break the board.
