Question about Fluval 306/406 Impeller Cover
Fluval 406 won't pull water
Light switch stopped working on fluval chi
The switch may have failed and will have to be replaced.
Oct 15, 2014 | Hagen Fluval Chi 5 Gallon Aquarium
How to stop fluval accent filter bubbles
How do u get the filter water to come down to the bucket?
Dec 06, 2013 | Fluval Fish
No bubbles from fluval q1
can't get airpod air pump to blow bubbles
Mar 27, 2013 | Hagen Fluval Q1 Aquarium Air Pump
Fluval chi aquarium light does not turn off, defective switch how do I repair it?
Much too late to help, I'm sure, but the cheapest fix would likely be to add a simple tap switch.When the tap switch is turned off, it cuts the power off and the light will go out. A tap switch is simply an outlet with a switch fitted. Plug the tap switch into the wall, plug the aquarium light into the tap switch and you're set. They're cheap at places like Home Depot, likely half the price of the replacement switch from Hagen, who makes Fluval. Also a great way to make it easy to turn filters on and off without having to pull the cord from the outlet.
Mar 09, 2013 | Fish
Pilot won't light
if gas check for cobwebs if ok replace pilot generator
Feb 15, 2013 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
How do i get a car owner's manual for peugeot 406 coupe
why don't you try to get a Haynes Manual for the peugeot 406? It has more advises and mechanical and electrical directions
Sep 09, 2012 | 2010 Peugeot 406 Coupe
Can someone help me with my fluval chi?
I did some research on the internet for this Fluval Chi-- I see that it is a 50 watt unit-- and others have had some problems with water circulation--- In other words, the pump is not moving enough water--
Could that be a clue?-- What other clues can you give to us to help you further?
Mack B
Jan 10, 2011 | Vacuums
Fluval 306/406 Impeller Cover Logo
80 people viewed this question
Top Fluval Fish Experts
J.D. Browning
J.D. Browning
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Are you a Fluval Fish Expert? Answer questions, earn points and help others
